Go to Post Everyone together now, say 'thank you'. - ebarker [more]
Unread 17-11-2016, 08:58
hadarsi320 hadarsi320 is offline
FRC #3075
hadarsi320 is an unknown quantity at this point
Grip Image processing
I'm trying to learn how to use Grip. I'm using the sample images from the wpilib website of the 2016 frc to get the outline of the tape.
I encounter some problem in the images that include a side shot of the goal that includes two sides of equal size, this is how it looks: http://imgur.com/a/ilKUe
Does anyone have any idea what should I change in the filters?
I tried changing it specifically for certain types of images but it ends up ruining images that are closer/further away.
Unread 17-11-2016, 09:22
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
Re: Grip Image processing
Invent some sort of deterministic behavior; ie always turn to the left target in this situation.
Creator of SmartDashboard.js, an extensible nodejs/webkit replacement for SmartDashboard
https://ligerbots.org
Unread 17-11-2016, 09:37
Data Nerd
FRC #0079
Sort by area of contour, then choose the first contour (i.e. the largest) You may have to do this robot side.
Unread 17-11-2016, 10:08
SamCarlberg's Avatar
SamCarlberg SamCarlberg is offline
GRIP, WPILib. 2084 alum
AKA: Sam Carlberg
SamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to behold
I'd do what Andrew recommended. You can iterate through the arrays in networktables and keep track of the index of the contour with the largest area.
WPILib
GRIP, RobotBuilder
Unread 17-11-2016, 10:29
KJaget's Avatar
KJaget KJaget is offline
Zebravision Labs
FRC #0900
Rookie Year: 2015
KJaget has much to be proud ofKJaget has much to be proud ofKJaget has much to be proud ofKJaget has much to be proud ofKJaget has much to be proud ofKJaget has much to be proud ofKJaget has much to be proud ofKJaget has much to be proud of
From experience shoot at the one on the right (i.e. the largest X value). The one on the left is a reflection from the driver station glass seen when you're trying to shoot in auto from the spybot location. Ask me (or the drivers we shot at, sorry) how I know.
Unread 17-11-2016, 10:50
EmileH's Avatar
EmileH EmileH is offline
it's not a water game, ok?
AKA: Emile Hamwey
FRC #1058 (PVC Pirates) & FF (NE Way You Want It)
EmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant future
For 1058's high goal autonomous, we just take the first contour array index which is always the left goal since our auto runs under the low bar and lines up with the left goal.
2016-present: High School Student, FRC 1058 PVC Pirates
2016: RiverRage 20 Champions, Battle of the Bay 3 Champions
2013-2015: Middle School Student, FRC 3467 Windham Windup
Unread 17-11-2016, 11:57
euhlmann's Avatar
CTO, Programmer
AKA: Erik Uhlmann
Rookie Year: 2015
The issue with this is that the areas may change as you turn towards a target. This creates a sort of extended donkey-haystack problem. It was an issue for us last season. Hence the strategy of choosing one to always use if the areas are sufficiently similar.
Unread 17-11-2016, 12:11
Hitchhiker 42's Avatar
Hitchhiker 42 Hitchhiker 42 is offline
Roboter
AKA: Mark Lavrentyev
FRC #4557 (FullMetal Falcons)
Rookie Year: 2015
Hitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to behold
You do need to be careful with this. If you pick the right one in this case, and start turning towards it, you'll end up with the left goal being larger. This can result in massive jiggling between the two goals and not deciding properly.
To do this, you need to pick one and stay with it even if it becomes smaller. This means you need to figure out a way to keep the one you want (maybe by sending a one-time angle to turn to and then using that).
2016 - NE District Championship Entrepreneurship Award
2016 - Hartford District Industrial Design Award
2016 - Waterbury District Engineering Inspiration Award
Unread 17-11-2016, 12:53
Data Nerd
FRC #0079
That depends on if you continue to update or if you use the image to determine where to turn then do it outside of the vision system using other sensors. Which is what I have always found to be more reliable.
Edit: Actually I'm going to expand on this.
Vision systems are running at, what, 30fps if you're good? If you only update your feedback variable 30 times a second bad things are going to happen with bouncing ANYWAY. A more sane way to do it would be to utilize gyro integration over a short time frame to allow you to compute the angle you are from the target and then turn that distance. The gyro is less noisy and updates faster.
