Go to Post You Texas boys and your fancy swerve drive. Why don't ya'll come up here to New England? I'm about to saddle me up a skid steer and herd ya'll fellers into a corner. - Tom Bottiglieri [more]
Unread 17-11-2016, 12:11
Hitchhiker 42's Avatar
Hitchhiker 42 Hitchhiker 42 is offline
Roboter
AKA: Mark Lavrentyev
FRC #4557 (FullMetal Falcons)
Rookie Year: 2015
Hitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to behold
Re: Grip Image processing
Originally Posted by Andrew Schreiber View Post
Sort by area of contour, then choose the first contour (i.e. the largest) You may have to do this robot side.
You do need to be careful with this. If you pick the right one in this case, and start turning towards it, you'll end up with the left goal being larger. This can result in massive jiggling between the two goals and not deciding properly.
To do this, you need to pick one and stay with it even if it becomes smaller. This means you need to figure out a way to keep the one you want (maybe by sending a one-time angle to turn to and then using that).
2016 - NE District Championship Entrepreneurship Award
2016 - Hartford District Industrial Design Award
2016 - Waterbury District Engineering Inspiration Award
