Go to Post To anyone who is discouraged about their team, don't let yourself get down. I've seen my team go from having a robot that barely moved (and I'm not kidding, we had keys falling out of gearboxes) to this year with a robot that is ACTUALLY GOING TO WORK. Don't lose hope, stick with FIRST! - ZipTie3182 [more]
Go Back   Chief Delphi > Competition > Regional Competitions
Thread Tools Rating: Thread Rating: 3 votes, 3.67 average. Display Modes
  #301   Spotlight this post!
Unread 17-11-2016, 14:22
Siri's Avatar
Siri Siri is offline
Dare greatly
AKA: 1640 coach 2010-2014
no team (Refs & RIs)
Re: Video Review Needs to Happen Now
Originally Posted by Lil' Lavery View Post
Have any events actually had an overturned call yet? There was one rescoring that was mentioned, but otherwise no event has had something overturned or adjusted. The primary concern is that most video review overturns would result in replaying matches, and thus the added schedule risk. It's not fair to penalize alliances for their strategic behavior based on the score/field conditions that are presented to them in real time, and then go back and adjust those via video review. For instance, if a team crosses a defense 3 or 4 times to damage it, they can't get the extra time they wasted crossing that defense back. Or if a team makes a call to ensure a capture at ~15seconds rather than scoring an extra couple balls based on their real time scoring, then have that scoring adjusted when you give the other alliance a breach that didn't exist previously. Virtually any case where errors are found in video review should mandate a replayed match. Thus the schedule concern.
As a coach, I'm happy to agree with this frustration. But we've gone years without this being true in real-time scoring, since as a referee it's completely normal to correct these things in non-video reviews before posting final score. It's annoying, but it's been part of the game since the advent of real-time scoring under T20 (identical to T15 last year). As long as it's clear when there will/won't be a replay, it's up to coaches to take it in our strategy.
  #302   Spotlight this post!
Unread 17-11-2016, 20:22
Blake, there's one other data point that I think could be useful in that analysis:
# of matches where video replay was available for use. That is, how many matches at the event in question could have possibly had a review? (Basically, how many matches did the event play? Unless, of course, it's elims-restricted, in which case it's how many elims matches were played.)
And the reason that that particular data point could be useful is that it will give a broad-spectrum picture of how used video replay could be, if available. Just as an example, if in 5 offseason events (that offer replay review) each with 50 matches replay is used 5 times and the call on the field is overturned* once, then you could say that there's a 2% use rate and when used, there's a 20% overturn rate--but overall, the overturn rate is 0.4% because only one call was overturned.
That sort of data can be used to figure out timing of events (and what the limits for review are) and ref performance. Both those numbers could be pretty important, the latter feeding into better ref crews if need be.
*Change of any sort to the result of the match--points, winner, you get the idea.
I'd suggest that "control" events track number of scoring changes (team or field staff initiated), and number of (denied, obviously) requests for review.
  #303   Spotlight this post!
Unread 17-11-2016, 20:29
gblake's Avatar
gblake gblake is offline
6th Gear Developer; Mentor
AKA: Blake Ross
no team (6th Gear)
Originally Posted by gblake View Post
After dealing with real-world constraints, thinking a bit more deeply, and getting some preliminary results; I, or whoever, might decide the experiments could be simplified without violating the integrity of the results, or they might add something.
Go for it!
