Go to Post We appreciate the time/effort of everyone who contributes to Chief Delphi... hopefully, someday soon we'll be experienced/seasoned enough to contribute advice ourselves... - Michael Blake [more]
Unread 11-18-2016, 11:32 PM
dash102 dash102 is offline
FRC #5968
dash102 is an unknown quantity at this point
Question SmartDashboard Problem
I am new to setting up a custom dashboard - right now, when I use putNumber(), where is the value I set going? I am able to retrieve it using getNumber(), but I can't get the value to display on the dashboard.
Unread 11-19-2016, 07:38 AM
AustinShalit's Avatar
AustinShalit AustinShalit is offline
no team (WPILib Suite Developer)
AustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of light
Re: SmartDashboard Problem
Hi there! Please make sure you followed all of the instructions here:
https://wpilib.screenstepslive.com/s...smartdashboard
You may also want to try to add a Connection Indicator (View -> Add... -> Connection Indicator).
Unread 11-19-2016, 11:28 AM
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
When you do this in robot code
SmartDashboard.putNumber("something", 1);
it goes on the SmartDashboard table.
So on a custom dashboard you might do (in Java)
NetworkTable sd = NetworkTable.getTable("SmartDashboard");
sd.getNumber("something"); // 1
Creator of SmartDashboard.js, an extensible nodejs/webkit replacement for SmartDashboard
https://ligerbots.org
Unread 11-19-2016, 08:25 PM
FRC #5968
Thanks! So do I have to be connected to the robot to be able to see the dashboard? Am I able to see it disconnected, just with no values in the spaces where values are supposed to be?
Unread 11-20-2016, 12:44 PM
euhlmann's Avatar
CTO, Programmer
AKA: Erik Uhlmann
Rookie Year: 2015
You have to be connected. If you are not connected, this (deprecated) throws an exception
NetworkTable.getTable("SmartDashboard").getNumber("something")
and this (the recommended way)
NetworkTable.getTable("SmartDashboard").getNumber("something", defaultValue)
returns defaultValue
However if you connect and then disconnect, the values returned will be the last known values.
Unread 11-23-2016, 02:42 AM
TylerHarmon TylerHarmon is offline
FRC #4499
TylerHarmon is an unknown quantity at this point
Yep, the values go into SmartDashboard.jar. You don't need to be connected to the robot to run that, you can run it while disconnected, and the values will be blank. You can also enable the edit mode and configure the layout of the dashboard, add dials/bars/graphs, etc. In addition, check out the SmartDashboard SFX, which allows for more visual control.
Last year I used this to display, on a dial and a bar, the amount of pressure that our pneumatic system had left so that our drivers could tell if they had enough pressure to fire or not. It's a great tool that's easy to use
Good luck!
Unread 11-25-2016, 01:59 AM
FRC #5968
Good luck!
Thanks for the info. I don't see any blank values at all when I check SmartDashboard.jar - when I try to add preferences, the preferences box doesn't update, and when I try to use a method like putNumber(), nothing new shows up. Do you have any code examples so I can see what I'm doing wrong?
