Go to Post We never play to lose, or even go easy. We play our best every match. - Paul H [more]
Unread 19-11-2016, 16:31
bobbysq bobbysq is offline
FRC #4646 (Team ASAP)
Rookie Year: 2015
bobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud of
Re: Wheel controller for FRC
A racing wheel controller really only works if you have the right drivetrain. I could see a modified wheel set up to be continuous working for in place turns on a swerve drive. It also works well if you have a drivetrain with 1 swerve wheel and 2 regular driven wheels. (Or, "Swartdrive" as I like to call it.) I can't really see a wheel controller working for a traditional drop drive, unless your driver was quick enough with it for the fast turns usually needed in FRC.
