Go to Post But now we know what's inside Shaun's backpack! ...Don Rotolo's plastic egg. - MishraArtificer [more]
Unread 19-11-2016, 20:25
dash102 dash102 is offline
FRC #5968
dash102 is an unknown quantity at this point
Re: SmartDashboard Problem
Thanks! So do I have to be connected to the robot to be able to see the dashboard? Am I able to see it disconnected, just with no values in the spaces where values are supposed to be?
Unread 20-11-2016, 12:44
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
You have to be connected. If you are not connected, this (deprecated) throws an exception
NetworkTable.getTable("SmartDashboard").getNumber("something")
and this (the recommended way)
NetworkTable.getTable("SmartDashboard").getNumber("something", defaultValue)
returns defaultValue
However if you connect and then disconnect, the values returned will be the last known values.
Creator of SmartDashboard.js, an extensible nodejs/webkit replacement for SmartDashboard
https://ligerbots.org
