Go to Post There is no feeling greater than being a part of a group that would walk through fire with you. Complete commitment, complete trust, and total respect. - Rich Kressly [more]
Unread 20-11-2016, 01:58
sakuram sakuram is offline
FRC #5700
sakuram is an unknown quantity at this point
Questions About Tools
Hello all,
We’re a small team going into our third competition season, and are, at the moment, working out of a garage. Soon, however, we’ll be getting a larger room, and with that, we need more tools and storage.
Our current ideas for possible items (desks, tools, etc.) is:
-Sortimos
-Workbench
-Pegboard
-Tubs
-A Grinder
-A Tablesaw
-A Vise
-A Vacuum
Are there any tools that you reccomend that we get this year, or over the years? Also, do you have any tips on organization? Any advice would help.
Unread 20-11-2016, 02:04
Chak Chak is offline
AKA: Thomas
FRC #4159 (Cardinalbotics)
Team Role: CAD
Chak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant future
Re: Questions About Tools
Get some Vexpro Versaframe stuff. Most of it is reusable, and you won't need fancy tools.
Unread 20-11-2016, 02:08
Ari423's Avatar
Ari423 Ari423 is offline
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant future
Some previous threads to look through:
https://www.chiefdelphi.com/forums/s...d.php?t=130316
https://www.chiefdelphi.com/forums/s...d.php?t=144010
https://www.chiefdelphi.com/forums/s...d.php?t=148746
https://www.chiefdelphi.com/forums/s....php?p=1561416
https://www.chiefdelphi.com/forums/s....php?p=1506575
Disclaimer: I didn't read through all of them so some may not apply to you.
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 20-11-2016, 02:59
bobbysq bobbysq is offline
FRC #4646 (Team ASAP)
Rookie Year: 2015
bobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud of
If you have long metal extrusion you want cut down, get a horizontal bandsaw. You can put a tube in the vice, walk away*, and wait for a loud clanging sound from across the room. In addition, you'll probably want a drill press for making holes in said tubes once you're done with them.
I would also recommend a 3D printer for making custom parts. It's good for various custom mounts and spacers. You can also print out items that are hard to get (a few teams printed pneumatic wheel hubs this year, no idea how that turned out) or ones you just can't bother to wait for. (AM's battery mount is easily printable, and the total filament cost will be a bit less than $14)
*Note: for safety reasons, you probably should watch your bandsaw while it's cutting.
Unread 20-11-2016, 08:42
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Not knowing what tools you already have, it's hard to make sure that you have the right stuff on our list. Leaving out the electric drills/screwdrivers and the Dremel, In our small shop, the most-used power tools are:
  • Miter/Bevel saw (though a horizontal band saw would be an improvement)
  • Drill Press
  • Bench Grinder
  • Vacuum Cleaner
Fairly Regularly used:
  • Portable Band Saw
  • Circular Saw (about 5", battery powered)
  • Reciprocating Saw
Given the saws that we have, the only time we would use a table saw most years is in building field elements or pit decorations. Between the safety issues and how occasionally we use these, we usually farm this work out to a mentor's garage, or bring in the table saw for a few days.
On the non-powered side, that's a great start (though I had too look up Sortimos; never heard of that brand until now), but I would probably also add some shelving units. We use a combination of heavy duty 24"x48" metal shelves and some medium duty rolling wire shelves about 36" x 16" deep, but let your specific needs and room size drive this.
Another organizational thing we did which has helped greatly was to build in a "pipe rack" along one wall. It consists of three rows by four columns of steel uni-strut (we had it; angle would have sufficed) angled up away from the wall at about 45 degrees above horizontal. We can store all sorts of stock there - right now, bottom shelf is steel, middle is aluminum, and top is wood. (and we have stored a rolled-up carpet below it at times). We also have a wire shelf above this where we store relatively light-weight, rarely accessed items.
Unread 20-11-2016, 11:38
RoboChair's Avatar
AKA: Devin Castellucci
Drill press and chop saw are both high on my suggested list. The list you posted, go ahead and get all of that as they will all be very useful.
Remember you can cut aluminum sheet on a table saw as long as it has carbide teeth, only let a mentor do this and take it slow. Rub some wax on the blade if you can and be prepared for a shower of hot chips.
11 Years and counting! Over a third of my life has been spent with FRC.
Unread 20-11-2016, 11:57
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
SawStop is a smart choice on table saw for students working with it. And aside from the safety mechanism, it's just a really nice saw.
Unread 20-11-2016, 12:07
mwmac's Avatar
mwmac mwmac is offline
JWBWIFWWWADD
AKA: Mike MacLean
FRC #2122 (Team Tators)
mwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond repute
Only if you do not plan on cutting aluminum...you must activate a bypass mode which nullifies the safety advantage.
http://www.sawstop.com/support/faqs
2016 Carson W 2122, 2052, 3538, 41, AZ North W 2122, 125, 498, MQA, Idaho F 2122, 3250, 3513, MQA, CCC W 2122, 9122, 6174, ICA
2015 Tesla SF IDA 2122, 3360, 2960, 1311 IRI SF 2338, 2122, 107, 234 UT F 2122, 3230, 3405, EEA, WFFA, AZ West W 2122, 3309, 5059, ICA
2014 Galileo QF 1717, 2122, 3683, 193 UT W 2122, 2996, 3191, ICA, CCC W 1678, 2122, 9073, ICA
2013 CalGames W 2122, 1678, 4171, Judges Award
2012 Newton QF 2122, 610, 488 Spokane W 2122, 1983, 4082, EEA
2011 Newton SF 1730, 2122, 11 IRI F 3138, 16, 2122, 1730, UT W 2122, 399, 3239, MQA, Seattle F 2122, 488, 2850, MQA
2010 Galileo SF 78, 51, 2122 UT W 1696, 2122, 3405, IDA, Sacramento F 2122, 2035, 1834, IDA,
2009 Sacramento F 2144, 692, 115, 2122, MQA
2008 Newton Sacramento W 2122, 1662, 115, CA
2007 PNW Regional Highest Rookie Seed
"Enjoying traveling to more distant events" since 2007
Unread 20-11-2016, 14:13
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
The Sortimos boxes look hard to scale, so I would look into simpler solutions (like generic plastic tubs) but it's good that you're thinking of sorting.
For FRC I would recommend a miter saw/cold saw over a horizontal bandsaw due to the smoother cut ends. I can get within 0.01" on the length of a tube with our miter saw. The disadvantage is that it is scary to use and screams when working, but I would still take it over a horizontal saw five days out of six.
I assume you already own a drill press and a vertical bandsaw. If you don't, buy one immediately. They are both incredibly useful tools.
Unread 20-11-2016, 14:25
headlight headlight is offline
headlight is an unknown quantity at this point
What do other teams use their bench grinders for? Our team doesn't do much work with steel and only recently got one for shaping lathe tools.
Unread 20-11-2016, 14:53
electroken's Avatar
electroken electroken is offline
Electron Tamer
AKA: Ken Pontbriant
FRC #0230 (Gaelhawks)
electroken is a jewel in the roughelectroken is a jewel in the roughelectroken is a jewel in the rough
We don't use a bench grinder very often, but it's been useful a few times. Sometimes we need a bolt just a thread or two shorter. Then there was that time in week 6 of build season in 2015 when we needed 40 pieces of 80/20 nuts TODAY and had to make them from a bunch of square nuts we had laying around. The grinder earned its keep that day.
Unread 20-11-2016, 16:36
snoman's Avatar
snoman snoman is offline
FRC #3275 (Accelerators 3134 & Regulators 3275)
snoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to behold
We have a good shop to use at our school but.
Cordless bandsaw
Good 18v cordless and impact drills
We have a stop saw and like it. It can cut wood and plastic. I do believe that they are expensive.
+1 versa frame you can do a lot without the need for high priced equipment. Make sure you are getting the KOP chassis
Coach of the Cass Lake Bena Regulators 3275 (Boys)and mentor Accelerators 3134(Girls)
https://www.facebook.com/accerleratorsandregulators/
https://www.youtube.com/channel/UCQU...Cr8I4wezAbMefA
Unread 20-11-2016, 18:40
MonroeM MonroeM is offline
FRC #3570
MonroeM is an unknown quantity at this point
You should get a transfer punch set. These are great for marking out anything and everything on metal. The most important thing in our shop that I could not live without is clamps. It is so worth it to get a bunch of sizes and types (machining, Irwin, etc.). Clamps are great for prototyping things before you make them permanent especially if that is all the material you have. Our bot is usually assembled all with clamps first before we bolt and drill holes. You can just never have enough clamps. I would also get all the bolts, nuts, and screws that you think you will need for the season at one time (the store might donate these to you instead of buying). Nothing is worse than having to stop a project to get more bolts. And please get Nylock nut for heaven's sake. If you don't know what these are you are missing out.
Unread 20-11-2016, 18:51
DaveL DaveL is offline
FRC #2976
DaveL is a jewel in the roughDaveL is a jewel in the roughDaveL is a jewel in the roughDaveL is a jewel in the rough
A grinder is great for trimming steel, but not so much for use on aluminum. The soft aluminum will attach to the wheel and clog it up.
Every time we cut aluminum it leaves a sharp edge. We use a basic belt/disk sander. (Found at Sears, HD and Lowes) to round (break) the edges. We also use a hand held deburring tool to clean up holes and interior edges.
For more control buy a variety of files: round, flat, fine, course, small and large.
Course files remove material quickly, fine files leave a smoother finish.
Round files are for smoothing holes and other interior shapes.
Large files are used for long parts and small files can get into tight spaces.
Like others have mentioned a band saw and a drill press are must haves.
You also need good lighting, a shop vac a floor vac and handheld drills. We like the battery powered handheld drills.
Yes a table saw is nice, but we are severely limited on space. Instead of a table saw we use a jig saw and a circular saw for cutting sheet material wider than our band saw.
Unread 20-11-2016, 22:53
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
When you do a lot of aluminum, you have to use the dressing tool after every ten minutes or so. For both aluminum and steel, a bench grinder is much faster than a hand file and is both faster and offers more control than a dremel or angle grinder for the jobs it can handle. Just remember to use vise grips for small pieces for better control and so you don't burn your fingers!
To be fair, we do use our bench grinder more for steel than aluminum - finishing cut bolt ends, removing flashing, going past deburring to actually rounding a corner, and occasionally even sharpening a blade.
We bought a unit with two different grain size wheels; if we were buying today, we'd probably just get one stone wheel and the other would be a wire brush to use for clean-up jobs including paint or coating removal.
