Go to Post Life is not about avoiding risk, but managing it. - dtengineering [more]
Unread 20-11-2016, 20:21
Bryce2471's Avatar
Bryce2471 Bryce2471 is offline
Alumnus
AKA: Bryce Croucher
FRC #2471 (Team Mean Machine)
Bryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud of
pic: Swerve Render
Unread 20-11-2016, 20:28
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Re: pic: Swerve Render
I really like your take on the bevel-beside wheel. It looks like it saves a lot of weight and space while eliminating some of the weaknesses in my design by putting the bearing around the turning gear and the spur gears below the turning gear. Overall this looks pretty robust.
It looks like you're missing a way to hold the CIM pinion on the shaft short of welding it on there, which I believe you can only do with a steel 11t pinion. Did you have another plan in mind?
Which gear did you need to make custom from aluminum? Or did you just mean modifying the turning gear?
What bearing are you using for the module rotation?
Unread 20-11-2016, 23:07
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
Thanks!
Correct. No method for this is in the CAD because I am not really decided. I was thinking of using loctite so that that it could be removed with a press and heat. What do you think is the best solution there?
... did you just mean modifying the turning gear?
That is what I meant.
Silverthin bearing with 0.25" x 0.25" cross section and 3" ID. This way the outer race can be clamped to the upper plate with 0.25" long shoulder bolts.
FLL Team Future imagineers
2010 Oregon State Championships: Winners
2011 International Invite: First place Robot design, Second Place Robot Performance
FRC Team Mean Machine
2012 Seattle: Winning alliance
2013 Portland: Winning alliance
2013 Spokane: Winning alliance
2014 Wilsonville: Winning alliance
2014 Worlds: Deans List Winner
Unread 21-11-2016, 00:12
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Originally Posted by Bryce2471 View Post
Thanks!
I know 1296 tried welded CIM pinions last year to save space in the same kind of situation (shaft needed to be cut short). Loctite could work I think, but I was imagining something with maybe a pin through the gear and shaft in addition to the keyway.
Those Silverthin bearings are pricey (albeit highly convenient)! I know teams that used them way back in the past have gotten sponsored.
Unread 21-11-2016, 00:16
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is online now
Can you shed some light on the wheel itself? Also, any chance for the full CAD?
Unread 21-11-2016, 00:17
mman1506's Avatar
mman1506 mman1506 is offline
Focusing on Combat Robots!
AKA: Marcus Quintilian
no team (WARP7)
Thanks!
Retention Compound (also made by Loctite) should work well. It can fill much larger gaps than threadlock.
2016: FRC 865 Mentor
Unread 21-11-2016, 00:18
Harrison.Smith Harrison.Smith is offline
Business, CAD, Mechanical
Harrison.Smith is a name known to allHarrison.Smith is a name known to allHarrison.Smith is a name known to allHarrison.Smith is a name known to allHarrison.Smith is a name known to allHarrison.Smith is a name known to all
Correct, we lathed the pinion in half and welded in addition to cutting the cim shaft down, only down side is that you can't remove the pinion.
“Rest and be thankful.” — William Wadsworth
Team 1296: 2014 - 2016
Unread 21-11-2016, 01:01
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
I was worried about this. I requested a quote from Silverthin but have not heard back yet. I know the equivalent bearing from VXB is $81.77!
The wheel is to be made from ABS (either on a printer or lathe) and the tread is polyurethane tubing from sun-ray that would be pressed on and bonded with a silicone adhesive like shoe goo. The basic layout and shape of the wheel should be visible in the cross section view.
Here is a link to the CAD. If you need STEP files let me know, and I can put that up too.
I like this idea, but I'm not sure how removable it would be.
Unread 21-11-2016, 03:22
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
Is there a STEP format file in the folder? I can't seem to find one.
Unread 21-11-2016, 03:41
Huh. That's interesting. So if/when the tread wears out, do you plan on just switching out the entire module or just the wheel?
Unread 21-11-2016, 13:23
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
There was not, but I just added one! Here is the link directly to the step file.
Yes. Or we could swap out the lower caster part, which ever is easiest. (I'm guessing just swapping out the wheel will be fastest because it only requires one bolt.) Then the old wheel can get new tread, so it can be used again later.
Unread 21-11-2016, 13:50
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Are you concerned about thrust loads generated from the bevel gears at all? I can't tell what bearings you're using on your drive shaft. Especially with the draft shaft being a nut/bolt combo, it seems like those thrust loads could slowly loosen the nut and creating play in the drive shaft.
Unread 21-11-2016, 14:22
Bryce2471's Avatar
Alumnus
AKA: Bryce Croucher
Do you mean the wheel shaft or the vertical shaft?
If you mean the vertical drive shaft, I am not worried about thrust loads because it is supported by 0.375" ID 0.875" OD flanged bearing, and I think it will be more than strong enough.
If you mean the wheel shaft, I am not worried about thrust loads from the bevel gears, because I am much more worried about the thrust loads from driving forces on the wheel.
Also none of the shafts are a nut/bolt combo. the vertical shaft is a solid aluminum live axle, the wheel shaft is a hollow steel dead axle with a bolt through the middle of it.
Unread 21-11-2016, 14:41
mman1506's Avatar
no team (WARP7)
Heat and some force should get it off without too much issue. CIMs are relatively cheap and reliable anyway.
Unread 21-11-2016, 16:42
Chris is me's Avatar
AKA: Pinecone
This would likely be a custom part, but you can definitely do press-fit CIM pinions. I prefer press fit to keyed pinions personally, whenever possible.
Otherwise, Loctite or something would probably hold on. I wonder if you could even put a snap ring groove into the output shaft of the motor?
