Go to Post "Dear Santa, all I want for Christmas is a game hint." - Gregor [more]
Unread 20-11-2016, 20:37
Maxwell777's Avatar
Maxwell777 Maxwell777 is offline
Is allowed to touch stuff now
AKA: Jackson Gray
FRC #0842 (Falcon Robotics)
Maxwell777 has a spectacular aura aboutMaxwell777 has a spectacular aura aboutMaxwell777 has a spectacular aura about
Re: Rate my Talon SRX breakout (EagleCAD)
Originally Posted by asid61 View Post
I was thinking more of 1 pad for forward or reverse, and adding another common ground pad. That way, in case you want to remove just the limit switch or the pot or whatever else, you can leave the pads you don't want modified unmodified. One of my pet peeves is when I solder more than 2 wires together, I try to desolder one, and another one comes loose and flicks hot solder somewhere.
Good point, now that you mention it I'll probably split the GND pad in half with a small junction between the two, like you'd have with thermals and such. Maybe into thirds. I'll have to see how much room I have to play with.
But why?
