Go to Post "Programming is 1% talent and 99% not getting distracted by the Internet." - FRC4ME [more]
Unread 15-11-2016, 15:56
BlackKnight219 BlackKnight219 is offline
FRC #4809
BlackKnight219 is an unknown quantity at this point
Need Mercanum Help
We are trying to program a mercanum drive prototype and only have two Talons and two Jaguars. How can we program it to run using these motor controllers? Help is much appreciated.
Thanks,
Team 4809
Unread 15-11-2016, 18:36
solomondg solomondg is offline
FRC #2898 (Flying Hedgehogs)
Rookie Year: 2016
solomondg is an unknown quantity at this point
Re: Need Mercanum Help
Here's a document that might help you out:
https://www.chiefdelphi.com/media/papers/download/2934
Unread 15-11-2016, 18:39
Ari423's Avatar
Ari423 Ari423 is offline
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant future
Is mercanum a new drive system, or yet another misspelling of mecanum? If it is a misspelling, check out Ether's mecanum analysis here. If it's a new drive system, I've never heard of it so good luck.
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 15-11-2016, 18:44
FRC #4809
Okay, thanks. Hopefully this helps.
Unread 16-11-2016, 12:20
adciv adciv is offline
One Eyed Man
FRC #0836 (RoboBees)
If you're using labview, it's already programmed in. See the 'Holonomic Drive' vi
Unread 20-11-2016, 22:39
Jonathan L. Jonathan L. is offline
FRC #1094
Jonathan L. is a jewel in the roughJonathan L. is a jewel in the roughJonathan L. is a jewel in the roughJonathan L. is a jewel in the rough
The TeleOp programming should be straightforward as described above. To your question about the different motor controllers.
There is not a ton of difference between the PWM signals used for different motor controllers. However, I would recommend re-calibrating all the motor controllers (really with any motor but) especially with option 1 below. Also, there may be a difference with linearity and I'm not sure how much software helps.
1. In the Begin VI use the Open 4 motors VI. On the drop-down menu below the VI select either Talons or Jaguars. Re-calibrate ALL motor controllers with THE SAME motor controller selected.
2. Use the same Open 4 motors VI but select Existing Motors from the drop-down. You can then wire in individual motor references, selecting the appropriate motor controllers for each motor.
Unread 20-11-2016, 23:15
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Except Jaguars. Talons and Victors and SPARKs and SD540s are practically interchangeable unless you're working at the edge of the envelope, but Jaguars use a different span of pulse widths than the others; be sure that you use the jaguar objects to control jaguars and talon objects to control talons. Calibration of the motor controllers is particularly important if you do NOT have an encoder on each wheel; if you are using encoders*, this should automatically compensate for any minor mis-calibration.
* I have read posts of teams who depend strongly on feed-forward and provide high values for P and D in their PID loops but leave I at zero, even for velocity control. I am not sure through any experience if this statement is true if you use the encoders this way, but my back-of-the-envelope figuring seems to indicate that this would still compensate for minor mis-calibration.
