Go to Post I love how your suggestion for MCC is one of the most elite robots of the year, and one of the World Champions. I also love that I really can't argue with you. - JVN [more]
Unread 21-11-2016, 00:12
asid61's Avatar
asid61 asid61 is online now
AKA: Anand Rajamani
FRC #0115 (MVRT)
Re: pic: Swerve Render
Originally Posted by Bryce2471 View Post
Thanks!
Correct. No method for this is in the CAD because I am not really decided. I was thinking of using loctite so that that it could be removed with a press and heat. What do you think is the best solution there?
Silverthin bearing with 0.25" x 0.25" cross section and 3" ID. This way the outer race can be clamped to the upper plate with 0.25" long shoulder bolts.
I know 1296 tried welded CIM pinions last year to save space in the same kind of situation (shaft needed to be cut short). Loctite could work I think, but I was imagining something with maybe a pin through the gear and shaft in addition to the keyway.
Those Silverthin bearings are pricey (albeit highly convenient)! I know teams that used them way back in the past have gotten sponsored.
Unread 21-11-2016, 00:16
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is online now
Can you shed some light on the wheel itself? Also, any chance for the full CAD?
Unread 21-11-2016, 00:18
Harrison.Smith Harrison.Smith is offline
Business, CAD, Mechanical
Harrison.Smith is a name known to allHarrison.Smith is a name known to allHarrison.Smith is a name known to allHarrison.Smith is a name known to allHarrison.Smith is a name known to allHarrison.Smith is a name known to all
Correct, we lathed the pinion in half and welded in addition to cutting the cim shaft down, only down side is that you can't remove the pinion.
“Rest and be thankful.” — William Wadsworth
Team 1296: 2014 - 2016
