Re: pic: Swerve Render
Here is a link to the CAD. If you need STEP files let me know, and I can put that up too. I like this idea, but I'm not sure how removable it would be. |
Is there a STEP format file in the folder? I can't seem to find one.
Huh. That's interesting. So if/when the tread wears out, do you plan on just switching out the entire module or just the wheel?
Yes. Or we could swap out the lower caster part, which ever is easiest. (I'm guessing just swapping out the wheel will be fastest because it only requires one bolt.) Then the old wheel can get new tread, so it can be used again later. |
Are you concerned about thrust loads generated from the bevel gears at all? I can't tell what bearings you're using on your drive shaft. Especially with the draft shaft being a nut/bolt combo, it seems like those thrust loads could slowly loosen the nut and creating play in the drive shaft.
If you mean the vertical drive shaft, I am not worried about thrust loads because it is supported by 0.375" ID 0.875" OD flanged bearing, and I think it will be more than strong enough. If you mean the wheel shaft, I am not worried about thrust loads from the bevel gears, because I am much more worried about the thrust loads from driving forces on the wheel. Also none of the shafts are a nut/bolt combo. the vertical shaft is a solid aluminum live axle, the wheel shaft is a hollow steel dead axle with a bolt through the middle of it. |
#7
Heat and some force should get it off without too much issue. CIMs are relatively cheap and reliable anyway.
