Go to Post If all you are is a nail, every hammer looks like a problem. - Alan Anderson [more]
Unread 21-11-2016, 09:41
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Re: Rate my Talon SRX breakout (EagleCAD)
Originally Posted by Maxwell777 View Post
According to OSH's design rules, everything passes DRC so I hope so. I was kinda worried about that myself for a bit, but like I said the DRC don't care so I guess I do.
On a somewhat related note, I was thinking about using some sort of epoxy or other goopy compound to seal all the parts on the board, particularly the .05" header, from metal chips and any other potential source of shorts. Know of anything that would be fairly easy to apply and non-conductive?
I've used This before and it works well. I do HIGHLY recommend that you use it in a WELL ventilated area.
A low temp drying oven is the recommended way to cure this.
___________________
- Tennyson, Ulysses
Unread 21-11-2016, 10:46
Maxwell777's Avatar
Maxwell777 Maxwell777 is offline
Is allowed to touch stuff now
AKA: Jackson Gray
FRC #0842 (Falcon Robotics)
Maxwell777 has a spectacular aura aboutMaxwell777 has a spectacular aura aboutMaxwell777 has a spectacular aura about
Now that you mention conformal coating it, I've also heard that it's possible to use nail polish as well. A spray-on like you suggested would probably work better though, speed up production of the 20-odd boards that I'm going to be making. I'll probably stick some tape over the solder pads to avoid coating those, as we need those for the board to work.
But why?
Unread 22-11-2016, 03:09
I'm jumping in probably a bit late and I'm short on time, so sorry if you've already though through this.
Q1/Q2 should likely be a MOSFET, right? Otherwise any voltage applied to the encoder pins will be pulled hard down by the transistor. You could put a resistor in series with the gate, but that will require a constant current draw.
We've been using latching molex connectors for quite a while and have liked them a lot. Consider connectors instead of soldering wires down.
Unread 29-11-2016, 13:09
Mr. Ackroyd's Avatar
Mr. Ackroyd Mr. Ackroyd is offline
FRC #3044 (OxBe4)
Mr. Ackroyd is on a distinguished road
Take a look at the attachments. This is what our team has used for the last two years.. They have worked great, keep our wiring in order and allows for easy trouble shooting and placement on the robot.
File Type: pdf Talon_SRX_Breakout_Board_Description_160220[1].pdf (617.2 KB, 18 views)
2016 CMP Tesla division Quaterfinals
2016 Finger Lakes Regional: Finalist on Alliance 3 (4930, 3044, 340) Industrial Design Award, Industrial Safety Award, Wildcard
2016 NYTVR: Quarterfinals on Alliance 8 (4930, 3044, 4481), Team Spirit Award
2015 Finger Lakes Regional Entrepreneurship award
2015 New York Tech Valley Regional FIRST Dean's List Finalist Award
2014 Finger Lakes Regional Industrial Safety Award, Team Spirit Award, Regional Finalists
2014 New York Tech Valley Regional Team Spirit Award
2013 WPI Regional Regional Winners, Team Spirit Award
2012 Finger Lakes Regional Regional Finalists
