Re: [FRC Blog] FIRST Choice 2017
We may be biased here at AndyMark, but we think it has been a net positive for FIRST Tech Challenge teams. ![]() Sent from my desk at AndyMark |
2010-2011 FTC Rules (R5 is the approved materials) 2016-2017 Game Manual Part 1 (RM01 is the start of what's approved.) In theory, the husk of an FTC robot might not have changed all that much for a DIY team since you could try and do it out of angle and flat aluminum. But if you're low-fabrication type like many FTC teams are, there are now many more options for structure, motors, wheels, gears, and other motion components--AndyMark, Rev, Actobotics, and Matrix are all making parts explicitly for FTC teams, and BaneBots and VEXpro parts are starting to make some inroads where their qualities are helpful. |
Re: NeveRest 60 in FRC
1) Set screw hub maladies. We released D-bore Nubs this year to help solve this problem. 2) The NeveRest 20 gearhead is less tolerant of shock loads than the 40 and 60 gearheads. (The number is the reduction from the bare motor: 20:1, 40:1, 60:1.) However, per Kate's blog post, only the NeveRest 60, am-3103, as pictured here has been announced as legal at this time and (as far as I've seen) FIRST hasn't announced whether switching (or removing) the gearhead will be an approved modification for the 2017 FIRST Robotics Competition. So that may be a moot point. Quote:
We've been doing FTC for three years and I think we've seen every possible failure these motors can have. Less common failures I've seen are magic smoke (only once and it was totally our fault), and cold solder joints under the black plastic caps (two times). Billfred is spot on about the two most common failures:
We've tried a lot of solutions to the D-shaft/set screw issue, a lot of which had slipping issues we couldn't solve. The most effective solution we found that still used the NeverRest gearheads was mounting these to the D-Shafts, then drilling through hex adaptor and the D-shaft and tapping to 4-40. About 90-95% of the D-shafts were hardened steel and required a carbide drill bit, 5-10% were mild steel. Before we settled on this solution, we lost ~5 motors in one season because a set screw would round out part of the D-shaft. We didn't try the nubs because the above was more effective at converting D to 0.5" Hex in our opinion. Shock load causing the individual gears to shear teeth is the most common problem (in my experience) with 20s, 40s, and 60s. The gearheads share the same design as the 2011 tetrix gearheads with spiraling pairs of spur gears held together by hopes and optimism. We lost ~15 motors in one season due to shock load, mostly in drive train applications. Quote:
My recommendation to any team using these motors in FRC (or FTC) is to remove the gearhead/buy the version without the gearhead. As others have said, these motors integrate very well into VersaPlanetary gearboxes. We put 2 of our 8 NeverRest motors into VP gearheads last season and experienced zero failures with them. This season we have put every single motor on the robot into a VP and have had zero failures so far. TL;DR: The motors are pretty good but replace the gearhead for serious use. |
#7
For FRC applications where you desire a motor w/ low speed, low power (to be more robust) and integrated encoder, the PG71's motor on a versaplanetary fits the bill much better. Last edited by AdamHeard : 11-22-2016 at 10:56 AM. |
#8
The point of my post was to alleviate some of the headaches for a team that chooses to use them. The biggest advantage I can see (the integrated encoder) also disappears when you put them into a VP because of the new encoder stages available for VPs. |
#9
You're probably right, the globes got removed right about when I started doing things other than pure software. I'm pretty sure window motors were no mods though.
#12
Dear CD,
As a robot inspector last year, I found one team had used the AM NeveRest motors on their robot so I had to have them remove the part before competing (and felt bad in the process because I suppose another inspector may have missed it, but felt better realizing that it may have gotten caught in a later inspection and they had ample time to swap out before their first match) So, from an inspection standpoint, this solves potential issues when FRC teams borrow FTC components that may be illegal. To me, this is the biggest win for FIRST by making the inspectors job easier and teams less likely to make this mistake. |
#13
This will help the problem some but it won't cure it. |
#14
How does that even happen? Globe motors have been illegal for years, right?
#15
With the general allowance of 'automotive motors' how does a team determine what is deemed an integral gearbox such as the window motor vs a non-integral gearbox like we saw with the mini-bot motors etc. For example I saw teams use door lock actuators last year, those have an integral gearbox. Could it be modified? The rules were not very clear last year, did anyone get an answer?
