| Thread Tools |
Rating:
Display Modes |
#271
Re: Registration 2017
I don't have my numbers from calculating this handy, but IIRC, attrition rates are a bit higher than average (12-15%) for the first two years, drop to about 9 or 10% for year three-to-four, and decay from there down to about 5-7% per year for teams with a decade of history. Edit: Here's the link to the data I used to calculate attrition rates, though not my results. Last edited by GeeTwo : 18-11-2016 at 13:38. |
#273
Focussed TBA GameDay coverage would bring depth to the picture that insiders see, and that is also important. |
#274
We have our first rookie team from the Canadian Yukon Territory.
Whitehorse (I've even been there once). |
#275
This is how many years ago the team was originally founded, not how many years they have played though. Some of these teams didn't play in all intervening years.
Special note: There is at least one team, 2479, whose rookie year is listed as 2008, however the school first had a team as far back as 1993. So depending on how you want to think about it you might want to list them as a 9 year veteran rather than a 24 year veteran team. I just ran this off the All_FRC_Teams_Ever database. If you want unadjusted rookie years you can use GeeTwo's spreadsheet that he posted a link to below. I took out the Israeli teams and the few vets languishing on waitlists that I know about. That left 237 missing non-Israeli vets. Years since Founding 1 ----- 46 are Missing (what would be second year teams if they come back this season) 2 ----- 43 Missing 3 ----- 29 Missing 4 ----- 25 Missing 5 ----- 21 Missing 6 ----- 18 Missing 7 ----- 12 Missing 8 ----- 13 Missing 9 ------ 6 Missing 10 ----- 2 Missing 11 ----- 3 Missing 12 ----- 1 Missing 13 ----- 6 Missing 14 ----- 2 Missing 15 ----- 2 Missing 16 ----- 2 Missing 17 ----- 1 Missing 19 ----- 2 Missing 20 ----- 1 Missing 24 ----- 2 Missing P.S. There's an attached pie chart comparing the relative percentages of each age group. Remember though that younger age groups generally come from a larger pool of teams, so this chart does not reflect equal sampling. I'll add a post later with relative percentages of the remaining rookie year populations (Thanksgiving grocery shopping takes precedence). Last edited by Mark McLeod : 21-11-2016 at 10:31. |
#276
My mom was born there, she's ecstatic.
#277
I'm not sure if the original North High School team has connections to 2479 or not, but from what I've heard, it isn't likely. We also supported the "rebirth" of 2479 these last two years based out of the Minneapolis College Prep Charter School, however the school shutdown last year, along with the rebirth of the Phoenix. It's a shame that a team has to die out when the school closes, however I have hope that maybe we'll see 2479 end up somewhere again, just like they did when the team started with us back in 2014. ![]() We have seen a bad retention rate when it came to teams sustaining in urban areas, with lack of funding, schools closing, or teachers leaving being common results. It's been a problem we've been working to solve in Minneapolis, but obviously some (like 2479) die off without being able to do anything about it. It's really hard to keep a team sustaining when a school closes and their entire student base separates to two high schools with FRC Teams. From what I've seen lack of funding, school closings, and mentors leaving are the most common factors for teams dying out, but I wonder what else could cause it. |
#278
If you spend some time digging through the Tecknokat's History Project: http://www.technokats.org/history-project/ you may be able to trace some of the early goings of the team. These documents helped a lot in piecing the story of 125 together. We learned a ton about our team and were able to reestablish some connections to help get the full history back. Our team goes all the way back to the beginning in 1992, but we missed a year in 1995. The team that existed back then split into a couple different teams in 1997 which is why our rookie year is 1998. Best Brando |
#279
Whaaaaaatttt?????? WHOA! So many robo-nerds <3
#280
![]() Last edited by GeeTwo : 21-11-2016 at 20:37. |
#281
Here's an expansion on the missing vets by rookie year.
# Missing – yrs ago – Rookie – # Surviving – % lost 1 ------- ( 12 years ) 2005 ------ 86 ---------- 1.2% 2 ------- ( 10 years ) 2007 ----- 114 ---------- 1.8% 1 ------- ( 17 years ) 2000 ------ 48 ---------- 2.1% 2 ------- ( 16 years ) 2001 ------ 75 ---------- 2.7% 2 ------- ( 15 years ) 2002 ------ 73 ---------- 2.7% 3 ------- ( 11 years ) 2006 ----- 102 ---------- 2.9% 1 ------- ( 20 years ) 1997 ------ 30 ---------- 3.3% 6 ------- ( 9 years -) 2008 ----- 173 ---------- 3.5% 2 ------- ( 14 years ) 2003 ------ 54 ---------- 3.7% 21 ------ ( 5 years -) 2012 ----- 290 ---------- 7.2% 12 ------ ( 7 years -) 2010 ----- 165 ---------- 7.3% 6 ------- ( 13 years ) 2004 ------ 82 ---------- 7.3% 13 ------ ( 8 years -) 2009 ----- 175 ---------- 7.4% 18 ------ ( 6 years -) 2011 ----- 234 ---------- 7.7% 2 ------- ( 19 years ) 1998 ------ 23 ---------- 8.7% 29 ------ ( 3 years -) 2014 ----- 305 ---------- 9.5% 25 ------ ( 4 years -) 2013 ----- 254 ---------- 9.8% 46 ------ ( 1 year --) 2016 ----- 410 --------- 11.2% 43 ------ ( 2 years -) 2015 ----- 329 --------- 13.1% 2 ------- ( 24 years ) 1993 ------- 3 --------- 66.7% Last edited by Mark McLeod : 21-11-2016 at 21:10. |
#282
Sorting Mark's number by year yields:
Years Attrition 1 11.2 2 13.1 3 9.5 4 9.8 5 7.2 6 7.7 7 7.3 8 7.4 9 3.5 10 1.8 11 2.9 12 1.2 13 7.3 14 3.7 15 2.7 16 2.7 17 2.1 19 8.7 20 3.3 24 66.7 After smoothing through the values beyond 8 years, this looks a lot like the usual attrition rate - biggest after two years, second biggest after first year, then improving steadily from third year to a long-term team. |
#283
Honeywell was the main sponsor for the early years, then General Mills for the resurgence beginning in 2008. So it began again in North high school in 2008 & 2009 before moving to Dunwoody, then Metro Tech, then College Prep. These are the school names registered with FIRST for each of the years they competed. Year ----- School 2016 ----- Minneapolis College Prep High School 2015 ----- Minneapolis College Prep High School 2014 ----- Minneapolis College Preparatory School 2013 ----- MetroTech Career Academy 2012 ----- MetroTech Academy High School 2011 ----- Dunwoody Academy High School 2010 ----- Dunwoody Academy High School 2009 ----- North High School 2008 ----- North High School 1997 ----- North Community High School 1996 ----- North Community High School 1995 ----- North Community HS 1994 ----- North Community High School 1993 ----- North Community High School Last edited by Mark McLeod : 22-11-2016 at 12:58. |
#284
Wow! You learn something new everyday. Can't wait to tell my mentor tomorrow that the team we mentored was originally the North High team. Thank you for this info! |
#285
A school in Guam has started two teams-6308 & 6309.
