Go to Post Of course, someone who can score on all rack levels while hovering autononmously 12 inches off the floor in his own home zone could probably have posted on CD while winning a regional.;) - Richard Wallace [more]
Unread 17-11-2016, 18:12
MikePerreman's Avatar
MikePerreman MikePerreman is offline
FRC #0247
MikePerreman is an unknown quantity at this point
Re: cannot ping roborio
well, new development if i connect over ethernet, then connect over wifi, all is well, untill, i connect to a different wifi, then back to the bot, it wont re-connect to the bot.
Programmer - A creature known for converting Caffeine into Code.
Unread 17-11-2016, 20:48
When it fails to connect to the roboRIO, to see if it helps you might try:
cmd prompt> ipconfig /renew
Your PC may be retaining the previous DHCP address it was given.
Unread 17-11-2016, 21:44
FRC #0247
alright, if this works, is there a way to automatically do this every time i connect to a new network?
EDIT: i found out that task scheduler existed.
Unread 21-11-2016, 16:16
FRC #0247
Alright, it seems to be working now. ill update if anything goes wrong. Thanks for the help, Mr. McLeod!
Unread 21-11-2016, 16:27
Glad you got it working!
Unread 21-11-2016, 17:26
FRC #0247
nope, i spoke to soon, its not re-establishing comms after putting ipconfig /renew into run once i connect to the bot radio. however, if i reboot, then, before connecting to any other networks, it connects fine, but once i connect to the shop internet, it no longer works, even with ipconfig /renew
Unread 21-11-2016, 17:36
FRC #0247
also, im not sure if this is related, but i keep dropping connection to the shop wifi, when i do, i can connect to the bot, 9/10. this is starting to sketch me right the frig out.
Unread 21-11-2016, 19:06
Here's another series of commands to try (all as administrator):
  • cmd prompt> netsh winsock reset
  • cmd prompt> netsh int ip reset
  • cmd prompt> ipconfig /release
  • cmd prompt> ipconfig /renew (just listing this for completeness)
  • cmd prompt> ipconfig /flushdns
You can try reinstalling or updating the PC's wireless driver through the Device Manager (Update Driver on the Driver tab for the wireless adapter) or if you can locate the latest network adapter driver software on the manufacturers website.
When the PC doesn't connect, you can try disabling, then re-enabling just the wireless adaptor.
See if you can find a local network expert to take a look at what your pc is doing. Without being able to put my hands on it I'm just going to be shooting in the dark at this point.
That doesn't mean I won't try.
Unread 21-11-2016, 19:32
G_rupp's Avatar
G_rupp G_rupp is offline
FRC #1108
G_rupp is an unknown quantity at this point
We had a Windows 8.? computer at a quick build a couple of years ago with a similar issue. The operator selected Public from the list of network location choices (Home, Work or Public) this caused it to block the IP of the wireless connection on the router.
Depending on the Windows version, this can be difficult to diagnose and reset to allow it.
Search for "how to change network location to private" and follow instructions based on Windows version.
Unread 22-11-2016, 15:27
FRC #0247
here is the response out of the terminal:
Microsoft Windows [Version 10.0.14393]
(c) 2016 Microsoft Corporation. All rights reserved.
C:\WINDOWS\system32>netsh winsock reset
Sucessfully reset the Winsock Catalog.
You must restart the computer in order to complete the reset.
C:\WINDOWS\system32>netsh int ip reset
Resetting Interface, OK!
Resetting , failed.
Access is denied.
Restart the computer to complete this action.
C:\WINDOWS\system32>ipconfig /release
Windows IP Configuration
No operation can be performed on Ethernet while it has its media disconnected.
Ethernet adapter Ethernet:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . : lan
Wireless LAN adapter Wi-Fi 2:
Link-local IPv6 Address . . . . . : fe80::7890:2e26:f32e:b804%14
Default Gateway . . . . . . . . . :
Tunnel adapter Teredo Tunneling Pseudo-Interface:
C:\WINDOWS\system32>ipconfig /renew
IPv4 Address. . . . . . . . . . . : 10.2.47.166
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 10.2.47.129
Tunnel adapter isatap.lan:
C:\WINDOWS\system32>ipconfig /flushdns
Successfully flushed the DNS Resolver Cache.
Unread 22-11-2016, 15:31
FRC #0247
yes, the network is private, and there is no network professional available to us, we could do something like team veiwer, but i dont know.
