Go to Post Test your code and your assumptions. - ShotgunNinja [more]
Go Back   Chief Delphi > Technical > CAD
Unread 21-11-2016, 20:27
ZoomZoom ZoomZoom is offline
FRC #3495
ZoomZoom is an unknown quantity at this point
Cad for a .375" hex sprocket
I can't find a cad for a hex .375" sprocket. I don't even know if one exists. Can you help me find one?
Unread 21-11-2016, 20:42
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is online now
Registered Muser
Cothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond repute
Re: Cad for a .375" hex sprocket
ANSI 25 and 35.
EDIT - Woops. Just saw the .375" bit. Your best bet is to take a 3/8" round hole and broach it to hex, or take a sprocket with the 6 hole mounting pattern and use this hub.
Unread 21-11-2016, 20:58
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
I've never seen a 3/8" hex bore sprocket, nor did I find one in a dozen web searches. I'm not really surprised, as the only 3/8" hex shafts I have seen have been on tools (e.g. drill bits) and intermediate gears in gearboxes, not on the output shafts. Most of the sprockets I have seen with less than 1/2" bore have been designed to fit directly on motor output shafts, and I have never noted a motor with a hex shaft.
If you want a 3/8" hex bore sprocket, the easiest route I can see is:
Purchase an AM-0278 or AM-0281, bore the hole out to 3/8", then use a 3/8" hex broach in an arbor press.
Edit: Sniped - and Cothron's second solution is simpler than mine.
