Go to Post This isn't an engineering fair and demonstration, it's FRC. Defense is part of the game. You can't expect a good FRC team to just sit there and get clobbered by a full-court shooter; they're going to engineer a solution to the problem. - Kevin Sevcik [more]
Unread 11-21-2016, 08:42 PM
kmckay's Avatar
kmckay kmckay is offline
FRC #5401 (Fightin' Robotic Owls)
Rookie Year: 2015
kmckay will become famous soon enough
Re: GRIP Deploy Not Working
Originally Posted by SamCarlberg View Post
That's bizarre. I'll see if I can reproduce this tonight. If not, you can use 1.5 and generate OpenCV code to run on the Pi without needing to deploy GRIP
Just to be clear, this is the ssh window, not the grip deploy log.
Unread 11-22-2016, 09:41 AM
kmckay's Avatar
Rookie Year: 2015
If its helpful, these were my Deploy window errors (which its my understanding that Pi users should ignore):
/usr/bin/java -Xmx50m -XX:-OmitStackTraceInFastThrow -XX:+HeapDumpOnOutOfMemoryError -jar '/home/pi/vision/grip/grip.jar' '/home/pi/vision/grip/project.grip'
Nov 19, 2016 3:38:27 PM java.util.logging.LogManager$RootLogger log
CONFIG: Configuration done.
CONFIG: GRIP Version: 1.5.0-rc3
2016-11-19 15:38:30.111:INFO::main: Logging initialized @3056ms
platform: /Linux/arm/
Nov 19, 2016 3:38:32 PM edu.wpi.grip.core.GripCoreModule onThreadException
SEVERE: Uncaught Exception on thread Thread[main,5,main]
com.google.inject.ProvisionException: Unable to provision, see the following errors:
1) Error injecting constructor, java.lang.UnsatisfiedLinkError: no ntcore in java.library.path
 at edu.wpi.grip.core.operations.network.networktables.NTManager.<init>(Unknown Source)
 at edu.wpi.grip.core.operations.network.networktables.NTManager.class(Unknown Source)
 while locating edu.wpi.grip.core.operations.network.networktables.NTManager
 while locating edu.wpi.grip.core.operations.network.MapNetworkPublisherFactory annotated with @com.google.inject.name.Named(value=ntManager)
   for the 2nd parameter of edu.wpi.grip.core.operations.Operations.<init>(Unknown Source)
 at edu.wpi.grip.core.operations.Operations.class(Unknown Source)
 while locating edu.wpi.grip.core.operations.Operations
   for field at edu.wpi.grip.core.Main.operations(Unknown Source)
 while locating edu.wpi.grip.core.Main
1 error
    at com.google.inject.internal.InjectorImpl$2.get(InjectorImpl.java:1028)
    at com.google.inject.internal.InjectorImpl.getInstance(InjectorImpl.java:1054)
    at edu.wpi.grip.core.Main.main(Main.java:52)
Caused by: java.lang.UnsatisfiedLinkError: no ntcore in java.library.path
    at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1864)
    at java.lang.Runtime.loadLibrary0(Runtime.java:870)
    at java.lang.System.loadLibrary(System.java:1122)
    at edu.wpi.first.wpilibj.networktables.NetworkTablesJNI.<clinit>(NetworkTablesJNI.java:57)
    at edu.wpi.grip.core.operations.network.networktables.NTManager.<init>(NTManager.java:78)
    at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
    at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62)
    at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
    at java.lang.reflect.Constructor.newInstance(Constructor.java:422)
    at com.google.inject.internal.DefaultConstructionProxyFactory$ReflectiveProxy.newInstance(DefaultConstructionProxyFactory.java:126)
    at com.google.inject.internal.ConstructorInjector.provision(ConstructorInjector.java:111)
    at com.google.inject.internal.ConstructorInjector.construct(ConstructorInjector.java:90)
    at com.google.inject.internal.ConstructorBindingImpl$Factory.get(ConstructorBindingImpl.java:268)
    at com.google.inject.internal.ProviderToInternalFactoryAdapter$1.call(ProviderToInternalFactoryAdapter.java:46)
    at com.google.inject.internal.InjectorImpl.callInContext(InjectorImpl.java:1092)
    at com.google.inject.internal.ProviderToInternalFactoryAdapter.get(ProviderToInternalFactoryAdapter.java:40)
    at com.google.inject.internal.SingletonScope$1.get(SingletonScope.java:194)
    at com.google.inject.internal.InternalFactoryToProviderAdapter.get(InternalFactoryToProviderAdapter.java:41)
    at com.google.inject.internal.FactoryProxy.get(FactoryProxy.java:56)
    at com.google.inject.internal.SingleParameterInjector.inject(SingleParameterInjector.java:38)
    at com.google.inject.internal.SingleParameterInjector.getAll(SingleParameterInjector.java:62)
    at com.google.inject.internal.ConstructorInjector.provision(ConstructorInjector.java:110)
    at com.google.inject.internal.SingleFieldInjector.inject(SingleFieldInjector.java:54)
    at com.google.inject.internal.MembersInjectorImpl.injectMembers(MembersInjectorImpl.java:132)
    at com.google.inject.internal.ConstructorInjector.provision(ConstructorInjector.java:120)
    at com.google.inject.internal.InjectorImpl$2$1.call(InjectorImpl.java:1019)
    at com.google.inject.internal.InjectorImpl.callInContext(InjectorImpl.java:1085)
    at com.google.inject.internal.InjectorImpl$2.get(InjectorImpl.java:1015)
    ... 2 more
I don't know how to view the 2 more.
I have also attached the GRIP log. I'm 90% sure this is the newly generated file from last night running from command line, but I just realized the date is wonky on my pi so I am not 100% sure. (file format changed to txt for cd post)
Unread 11-25-2016, 02:52 PM
kmckay's Avatar
Rookie Year: 2015
Worth noting I've got the RIO on the network now, no change.
I've also changed the GRIP to not report out to network tables.
No change from either.
Worth noting Driver Station gives a DNS error, though I can ping the RIO. I think this is a Win10 network problem.
Unread 11-25-2016, 05:14 PM
kmckay's Avatar
Rookie Year: 2015
It seems like the interwebs think this error, in an OpenCV context, comes from failing to provide a required argument.
Anyone? Anyone? Bueller?
