Go to Post (pfft, kid... I sound like I'm Baker's age) - Amanda Morrison [more]
Unread 10-11-2016, 11:22
Gilga Gilga is offline
FRC #2169
Gilga is an unknown quantity at this point
[FTC]: Modern Robotics Module Communication Issues
I mentor 9 FTC teams in my school, and am continuing to have an issue I'm having a hard time finding a fix for. So here is my testing and results.
When I connect the phone to some power distributions I have an issue of nothing showing up in the app. I power cycle, have everything plugged in and off, and then turn on the power distribution. The app does not launch, nor does it prompt me to launch. I use different cables, and try a few more power cycles to no avail. I then take the phone, unchanged and plus it in to the power distribution of another teams robot. I turn on the power distribution while the phone is plugged in and a prompt comes up to launch the app, and from there everything is working and communicating.
From this I have concluded that it isn't the phone, it isn't the cables, and I don't believe the modules plugged in have anything to do with it. Has anyone else found similar results?
Unread 22-11-2016, 16:50
xitaqua xitaqua is offline
COPUS MEMBER
no team (BERSDT)
xitaqua is a splendid one to beholdxitaqua is a splendid one to beholdxitaqua is a splendid one to beholdxitaqua is a splendid one to beholdxitaqua is a splendid one to beholdxitaqua is a splendid one to beholdxitaqua is a splendid one to behold
Re: [FTC]: Modern Robotics Module Communication Issues
Have you looked into upgrading the firmware ?
Unread 23-11-2016, 02:37
FRC #2169
The firmware on the modules was all done recently, and they didn't say to send in the Power Distros.
Unread 23-11-2016, 09:51
phurley67 phurley67 is offline
Programming Mentor
phurley67 is an unknown quantity at this point
So have you done the reverse test and plugged different phones into the non-functioning robot? If nothing appears to work with that power distribution -- it may be that the port on the power distribution block is bad/damaged.
I have also resolved similar issues by just power cycling the phone, which you did not mention, but I am assuming you have tried.
Unread 26-11-2016, 14:38
godkane godkane is offline
FRC #3875
godkane is an unknown quantity at this point
Have you tried upgrading the firmware on the phones? I had a similar issue and just upgraded to the latest firmware version solved it. Using the self-check in the DS or RC also helps.
Unread 26-11-2016, 18:28
MattRain MattRain is offline
AZ FTC AF, FTC #2844 and FTC #8640
FRC #1492 (Team Caution)
Team Role: RoboCoach
MattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant futureMattRain has a brilliant future
Have you been supporting the USB's as they come out of the modules? The poor design of the modules makes it prone to USB dropouts and brakes if used improperly.
Ways to support.
3D (We use the DJ Models)
http://www.thingiverse.com/thing:1099628/#files
http://www.thingiverse.com/thing:1106087
http://www.thingiverse.com/thing:1096699
Or
- Rolled up tape
- Wood
2015 FTC WORLD CHAMPIONS
www.valleyx2844.com
Twitters: Valley X & Trojan Robotics & Team Caution
(World Championship Counter: 5)
*All my posts reflect my opinion, not my teams.*
"I WANT CHEETOS!" - Bad Lip Reading 2016 <-- ME
Unread 30-11-2016, 14:07
Isonine Isonine is offline
FRC 4904 FTC 8375
FRC #4904
Isonine is an unknown quantity at this point
Ways to support.
Or
- Rolled up tape
- Wood
We had an issue last year with one of our motor controller disconnecting from the USB even though they were supported with 3d printed supports. We chose the last resort option which was super glue the mini USB plug (the plastic surrounding the connector, not the metal itself) to the plastic on the motor controller, super glue the support to the electrical board, and zip tie the entire thing.
3 months later (without failure), we just broke off the super glue and everything was fine.
FTC 8375
2016 FTC World Finalists (8375, 7013, 3595)
2016-2017:
Google Think + 2nd Inspire
2015-2016:
Worlds Finalist Alliance Captain, West Winning Alliance Captain, NorCal Winning Alliance + Control, Daly City Connect, Saratoga Winning Alliance + Inspire
2014-2015:
Elk Grove Winning Alliance, Play Space Winning Alliance + Inspire
Unread 01-12-2016, 11:14
Interesting. We haven't had any issues since we started using them. Sounds like it was just one bad motor controller, and not the rest?
www.valleyx2844.com
