Go to Post Kit wheel? Someone probably has them. N-tooth IFI sprocket? You might get lucky. Part Made By A Local Company When You're Competing 800 Miles Away? Bring three. - Billfred [more]
Go Back   Chief Delphi > Technical > CAD
Unread 22-11-2016, 10:32
carpedav000's Avatar
carpedav000 carpedav000 is offline
Studenting is hard, but worth it!
AKA: David Carpenter
no team (Jerry-Rigg school of DuctTapeology)
carpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant future
Looking for Help With Designing Custom Gearboxes
I'm working on modeling a drivetrain in my free time. Due to the way things were designed, it needs a custom gearbox. I have never designed a custom gearbox, so I was wondering if anyone had any tips/tricks they would be willing to share
It isn't shiny enough.
Unread 22-11-2016, 17:41
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is offline
Re: Looking for Help With Designing Custom Gearboxes
First off, I'd recommend you post the designs here after you finish. It's much easier to offer critique and suggestions when we can see the design itself.
-As always, add .003-.005" to the center distances of your gears.
-While you're designing, consider how you would replace a motor, gear, shaft, bearing, etc., were one to fail.
-Don't put snap rings or e-clips between loads.
-Consider how you're manufacturing the gearbox before you design it. A gearbox to be made on a CNC mill should probably look different from a gearbox to be waterjetted.
-Look around on here. There are some beautiful gearbox designs that people have posted here.
-Don't be afraid to use something other than the .5" hex bore 20DP standard Vex gears for your first reduction. The 20DP gears are a go-to for many reasons, but they can also be a little overkill for the high speed, low torque stage. Consider a smaller pitch gear, or belts, or something more creative. But make sure you justify stepping away from the standard, and back it up with solid engineering to make sure you aren't cutting corners.
-When you're making the CAD model, build it with the expectation that you're going to change it. If editing a dimension or placement of a feature takes longer than it did to originally correct it, than you probably need to work on your CAD skills. Team 973 has some great videos on improving this if you're using SolidWorks.
If you have any other questions, let me know. Good luck!
