#31
Re: 3D Printed Parts on an FRC Robot?
You could try using the model of some pulley stock (with the correct tooth count, profile and pitch of course) so that you don't need to draw out the profile in a sketch. Then add whatever bolt holes or bores you need.
#32
Thanks, however part of my motivation is learning how pulleys are designed from the ground up.
#33
I'm not saying it isn't vapor smoothed ABS, but there are other ways to get that effect. |
#34
Check out the Gates belts and metals design manual. Gates has lots of information about the design of timing belts and pulleys. Also, Gates refers to their pulleys as "metals." Just a little tip to navigate their site.
#35
I can't speak for everyone else, but I do know that Autodesk Inventor has a tool that allows you to generate standard sprockets/gears/pulleys of various sizes and tooth counts.
