Go to Post That's some sexy use of aluminium - Bharat Nain [more]
Unread 23-11-2016, 13:18
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
Re: SFX Dashboard Tabs
I believe you can edit the file directly. It's a tar with YAML for the layout inside. Just change the "name" field for the tab
Creator of SmartDashboard.js, an extensible nodejs/webkit replacement for SmartDashboard
https://ligerbots.org
Unread 23-11-2016, 16:57
phurley67 phurley67 is offline
Programming Mentor
phurley67 is an unknown quantity at this point
Thanks, I peeked at the file and did not realize it was a tar file (I could see the yaml, but was not going to change it with all the binary noise at the top).
It worked, now if I could only figure out a way to switch tabs programatically.
Unread 23-11-2016, 17:29
euhlmann's Avatar
CTO, Programmer
AKA: Erik Uhlmann
Rookie Year: 2015
Don't think it's possible. You should make your own dashboard; it's quite easy.
First, get the NetworkTables library. You can build the official C++ and Java libraries using the project source code (follow readme.md instructions, then add to your project in C++ or Java). There is also Python, C#, and node.js (disclaimer: my own project, used for my webkit smartdashboard)
Then, you can connect to the robot as follows (Java)
// sets the address to roborio-862-frc.local
// You can also use setIPAddress(String address)
NetworkTable.setTeam(862);
NetworkTable.setClientMode();
NetworkTable.init();
// the table for the WPILib SmartDashboard class
// Preferences and LiveWindow are Preferences and LiveWindow
NetworkTable smartDashboard = NetworkTable.getTable("SmartDashboard");
// the default value parameter is returned from get*() if the client is not connected
double defaultValue = 0;
System.out.println(smartDashboard.getNumber("myNumberVariable", defaultValue));
