Go to Post It would be a (relatively) level* playing field *...though it seems like the actual field will be anything but level. - Jacob Bendicksen [more]
Unread 23-11-2016, 13:48
DRow's Avatar
DRow DRow is offline
VEX Robotics Marketing Coordinator
AKA: Dillon Row
FRC #0148 (Robowranglers)
DRow has a reputation beyond reputeDRow has a reputation beyond reputeDRow has a reputation beyond reputeDRow has a reputation beyond reputeDRow has a reputation beyond reputeDRow has a reputation beyond reputeDRow has a reputation beyond reputeDRow has a reputation beyond reputeDRow has a reputation beyond reputeDRow has a reputation beyond reputeDRow has a reputation beyond repute
VEXpro 2017
Announcing the VersaPlanetary v2! This updated design is now held together with screws that install on the "back" (motor side) of the housing. This means that the gearbox can be disassembled to change gearsets without removing the gearbox output from the robot. Bosses have been added to the sides of the gearbox so when it is side-mounted you can "crank down" on the mounting screws without accidentally misaligning a ring-gear stage.
Note: The v1 & v2 input and output blocks cannot be mixed and matched - A v2 input block must be used with a v2 output block. Ring gears and gear kits are compatible between v1 & v2
In addition, base VersaPlanetary kits now include an optional pilot ring that will allow users to pilot the VersaPlanetary on a 0.75" hole, instead of relying on screw clearances to locate the gearbox. The plastic motor mounting plates now pilot on the input block.
The VersaPlanetary v2 is in stock now! Be sure to order yours now to prepare for the upcoming season. Check out this link for more information: http://www.vexrobotics.com/vexpro/mo...planetary.html
Team 148
Student (09-11)
Mentor (12-14, 16-?)
Unread 23-11-2016, 13:52
AdamHeard's Avatar
Lead Mentor
Re: VEXpro 2017
These look like some nice tweaks to make the Versaplanets even better.
Are there any other new products this year?
Unread 23-11-2016, 13:54
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Re: VEXpro 2017
Originally Posted by DRow View Post
Announcing the VersaPlanetary v2! This updated design is now held together with screws that install on the "back" (motor side) of the housing. The VersaPlanetary v2 assembly is now held together with screws that install on the "back" (motor side) of the housing. This means that the gearbox can be disassembled to change gearsets without removing the gearbox output from the robot. Bosses have been added to the sides of the gearbox so when it is side-mounted you can "crank down" on the mounting screws without accidentally misaligning a ring-gear stage.
Just when you though it couldn't get better.....
Unread 23-11-2016, 13:55
ClockworkGold's Avatar
ClockworkGold ClockworkGold is offline
Wears Sparkly Gold Pants
AKA: Andrew F.
FRC #2169 (KING TeC)
ClockworkGold is a splendid one to beholdClockworkGold is a splendid one to beholdClockworkGold is a splendid one to beholdClockworkGold is a splendid one to beholdClockworkGold is a splendid one to beholdClockworkGold is a splendid one to behold
Re: VEXpro 2017
Very nice addition to an already solid product line! Fingers crossed for more additions before Steamworks
2014: FRC 2169 Scouting and Spirit & FTC 7897 CAD
2015: FRC 2169 CAD, Strategy, Scouting & FTC Mentor 3385, 3387, 4509, 7899, 7900
cad321 cad321 is offline
Jack of all trades, Master of none
AKA: Brian Wagg
FRC #2386 (Trojans)
cad321 is just really nicecad321 is just really nicecad321 is just really nicecad321 is just really nice
Re: VEXpro 2017
And to think I just bought the now v1 versa planetaries last week. Oh well. Time to stock up on new parts again. Very nice tweaks to the already great product line.
Unread 23-11-2016, 14:04
Brandon Holley's Avatar
Re: VEXpro 2017
Solid improvements! Nice job Vex team.
-Brando
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 23-11-2016, 14:10
sportzkrazzy's Avatar
sportzkrazzy sportzkrazzy is online now
AKA: Zac
FRC #1592 (Bionic tigers and 801 Horse power)
sportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant futuresportzkrazzy has a brilliant future
Send a message via AIM to sportzkrazzy
Re: VEXpro 2017
Why did they get rid of the headphone jack though? =p
Unread 23-11-2016, 14:15
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
Re: VEXpro 2017
Good Stuff!
Am I correct that the changes are all maintenance and assembly related and the are no changes to load ratings, etc?
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Re: VEXpro 2017
How do the new mounting screws work with the larger motors? Different mounting plates to account for bolt access? I'm sure you guys figured it out, but it would be nice to see some pictures of the access with each of the different compatible motors attached!
2016: Lake Superior WFFA
Unread 23-11-2016, 14:22
saikiranra's Avatar
saikiranra saikiranra is offline
UCI
AKA: Saikiran Ramanan
FRC #3476 (Code Orange)
saikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond repute
Re: VEXpro 2017
It is mentioned that old and new blocks can't be mixed, but is it safe to assume we can use the old versa encoder with this?
2014 - Current: Team 3476 Electronics, Programming, and Scouting Mentor
2011 - 2014: Team 696 Student and Drive Coach
Unread 23-11-2016, 14:25
AKA: Brian Wagg
FRC #2386 (Trojans)
Re: VEXpro 2017
They say that the stages are interchangeable between the two revisions. Because the versa encoder is a stage and not an input/output block, I would assume we can still use them in the v2.
jwfoss jwfoss is offline
Chasing Elegant Simplicity
AKA: Justin Foss
Re: VEXpro 2017
I second that.
Unread 23-11-2016, 14:28
frcguy's Avatar
frcguy frcguy is offline
Unregistered Unuser
AKA: Nicholas Dal Porto
FRC #5940 (B.R.E.A.D.)
Team Role: Tactician
frcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond repute
Re: VEXpro 2017
Awesome stuff! We'll be grabbing some of these this offseason.
2016: Team 5940 (Silicon Valley Regional Rookie All-Star and Quarterfinalist, Curie Quarterfinalist)
Volunteer: 2016 (Chezy Champs Field Reset, Capital City Classic FTA, MadTown ThrowDown FTA)
Unread 23-11-2016, 14:31
Karthik Karthik is offline
VEX Robotics GDC Chairman
Karthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond repute
Re: VEXpro 2017
Hi Jon,
I think you'll find what you're looking for in these two documents, including some handy charts to let you know exactly which screws are needed with each motor and stage combination.
VersaPlanetary v2 User Guide
VersaPlanetary v2 Screw Guide
These documents and more can be found on the VersaPlanetary product page in the "Docs & Downloads" section.
:: Karthik Kanagasabapathy ::
"Enthusiasm is one of the most powerful engines of success. When you do a thing, do it with all your might. Put your whole soul into it. Stamp it with your own personality. Be active, be energetic, be enthusiastic and faithful and you will accomplish your object. Nothing great was ever achieved without enthusiasm" -- R.W. Emerson
My TEDx Talk - The Subtle Secrets of Success
Full disclosure: I work for IFI and VEX Robotics, and am the Chairman of the VEX Robotics and VEX IQ Game Design Committees
Unread 23-11-2016, 14:49
bdaroz's Avatar
bdaroz bdaroz is offline
Programming Mentor
AKA: Brian Rozmierski
FRC #5881 (TVHS Dragons)
Rookie Year: 2016
bdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud of
Re: VEXpro 2017
Originally Posted by Karthik View Post
Hi Jon,
Thanks Karthik,
One note - Pg 9 of the user's guide has everything called a "CIM Motor Output Shaft" in the tables, despite the different header names. (Copy-and-paste fail )
