Go to Post By the way, safety glasses are so in style now, :) - LightWaves1636 [more]
Unread 23-11-2016, 17:40
Jon Jack's Avatar
Jon Jack Jon Jack is offline
VEX Robotics
no team (No Team)
Jon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond repute
Send a message via AIM to Jon Jack
Re: VEXpro 2017
Originally Posted by Nuttyman54 View Post
Good Stuff!
Am I correct that the changes are all maintenance and assembly related and the are no changes to load ratings, etc?
Correct, the load ratings are the same as the VersaPlanetary v1.
Originally Posted by saikiranra View Post
It is mentioned that old and new blocks can't be mixed, but is it safe to assume we can use the old versa encoder with this?
Yes, the integrated encoder is compatible with the VersaPlanetary v2
Originally Posted by Munchskull View Post
Echoing what everyone has said, looks like very solid changes to an amazing product. My one question is, weather or not shafts will be inter changeable between the two.
Yes, output shafts are interchangeable between v1 and v2.
Originally Posted by Rob Stehlik View Post
Did you fix the issue with the pins coming out of the carrier plates? This is a problem on the 7:1, 9:1, and 10:1 stages. We fought this all last season, and even tried epoxy and welding with mixed results.
Only the base kits were changed in VersaPlanetary v2.
Team 1538 / The Holy Cows, 2005-2016
