Go to Post "It's not a bug, it's an unlisted feature." - Barry Craig [more]
Unread 23-11-2016, 15:19
jman4747's Avatar
jman4747 jman4747 is offline
Just building robots
AKA: Josh
FRC #4080 (Team Reboot)
Team Role: CAD
jman4747 has a brilliant futurejman4747 has a brilliant futurejman4747 has a brilliant futurejman4747 has a brilliant futurejman4747 has a brilliant futurejman4747 has a brilliant futurejman4747 has a brilliant futurejman4747 has a brilliant futurejman4747 has a brilliant futurejman4747 has a brilliant futurejman4747 has a brilliant future
Quick fix for getting serial data from CMUcam5 Pixy
So I have a way to get the data from the pixy cam to the RoboRIO via USB at 50 frames a second. The pixy is plugged in to an Arduino Uno with the induced cable and the Arduino is plugged into a PC or RoboRIO via USB. This assumes the pixy is set up to track one object (ie. reflective tape). I set up the Arduino running this:
#include <SPI.h>
#include <Pixy.h>
// This is the main Pixy object
Pixy pixy;
void setup()
  Serial.begin(57600);
  Serial.print("on\n");
  delay(1000);
  Serial.print("waiting\n");
  pixy.init();
void loop()
  static String C = "wait";
  int j;
  uint16_t blocks;
  char buf[32];
  // grab blocks!
  blocks = pixy.getBlocks();
  if (Serial.available() > 0)
    C = Serial.readString();
    if (C == "go")
      Serial.print("User command: " + C + "\n");
      //delay(500);
      //Serial.print("Data start in 1 second!\n");
      delay(1000);
    else
// else
  if(C == "go")
     if (blocks)// If there are blocks detected, print them!
                  //i++;
                   // do this (print) every 2 frames because printing every
                   // frame would bog down the Arduino(not)
                   /*if (i%2==0)
       for (j=0; j<blocks; j++)
       //sprintf(buf, "  block %d: ", j);
       //Serial.print(buf);
       pixy.blocks[j].print();
/*  else if(C == "stop")
    C = "wait";
  else if(C == "wait")
    //C = "hold";
    delay(250);
  else if(C == "light")
    Serial.print("not implemented\n");
    C = "wait";
    delay(250);
  else if(C == "help")
    Serial.print("command list:\ncommand: go = activate camera & start data stream\n");
    Serial.print("command: wait = stop data stream\n");
    Serial.print("command: light = toggle LED ring on or off\nLED ring cannot be toggled off if camera is active\r\n");
    C = "wait";
    delay(250);
  else
    Serial.print("bad command\n");
    C = "wait";
    delay(250);
I then plug in the Arduino to a PC or the RIO and run the attached LabVIEW snippet. The main difference between running it on the computer and the RIO is the visa resource name. On the computer it is "COM3" on the RIO it is "ASRL3::INSTR".
Data comes over USB like this: "sig: 1 x: 164 y: 78 width: 81 height: 71"
I'm not a C programmer or all tha good at LabVIEW so this is all very rough but it seems to get the job done with minimal latency.
ID:	21297  Click image for larger version
Alumni, CAD Designer, machinist, and Mentor: FRC Team #4080
Mentor: Rookie FTC Team "EVE" #10458, FRC Team "Drewbotics" #5812
#banthebag
#RIBMEATS
Unread 23-11-2016, 19:54
dirtbikerxz's Avatar
dirtbikerxz dirtbikerxz is online now
Captain | Driver | CAD | Junior
AKA: Rohit Gondi
FRC #3991 (KnightVision)
Team Role: Driver
Rookie Year: 2015
dirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud of
Re: Quick fix for getting serial data from CMUcam5 Pixy
Can you make the Labview code downloadable please. Thanks. Also, I'm assuming you are running that in Periodic tasks on the roborio right? I'm also extremely new to labview.
Team 3991: Driver since freshman (2015-), Captain since sophomore (2016-), CADer
"The human condition is not perfect. We are not perfect specimens, any of us. We're not robots." - Michael Ovitz
My posts may or may not reflect the views of my team, they are my opinions, and mine alone.
Unread 23-11-2016, 20:01
jman4747's Avatar
AKA: Josh
Team Role: CAD
Cool thing is it is downloadable. Click on the image and open it in a new tab then open a blank VI. Click and drag the image from your web browser and on to the VI block diagram. This is called a VI snippet, see here: http://www.ni.com/tutorial/9330/en/
And yes this belongs in periodic tasks.
#banthebag
#RIBMEATS
Unread 23-11-2016, 20:51
cad321 cad321 is online now
Jack of all trades, Master of none
AKA: Brian Wagg
FRC #2386 (Trojans)
cad321 is just really nicecad321 is just really nicecad321 is just really nicecad321 is just really nice
The code is awesome. Thanks for sharing. That being said, telling me about VI snippet tool I think is just as awesome. That's going to be super usefu .
Unread 23-11-2016, 20:55
AKA: Rohit Gondi
Team Role: Driver
Rookie Year: 2015
Woah. That's cool. Also what does ur begin.vi look like?
Unread 23-11-2016, 21:22
jman4747's Avatar
AKA: Josh
Team Role: CAD
There isn't anything related to serial communication in the begin VI. In this case having the initialization code outside of and feeding the loop is effectively the same as having it in the begin VI. The only difference is that code in the begin VI executes before code in periodic tasks. There is also no need for a Refnum set/get VI.
The begin VI exists to help organize code that only needs to execute once and at the beginning of the program, and to ensure that code that initializes something executes before that thing is called in other VIs like periodic tasks or teleop.
#banthebag
#RIBMEATS
Unread 25-11-2016, 05:24
jman4747's Avatar
AKA: Josh
Team Role: CAD
This has been turned into a git hub repo here: https://github.com/FRC4080Turner/Pixy-cam-to-RoboRIO. I will be updating it tomorrow and over the weekend after I have tested this on the RIO again. I will also be testing the Pixy with this lens: http://www.ebay.com/itm/122198892672 and its standard lens on 2016 reflective tape targets.
#banthebag
#RIBMEATS
Unread 27-11-2016, 16:04
jman4747's Avatar
AKA: Josh
Team Role: CAD
So far the Pixy has done a pretty good job of finding reflective tape lit with green LED rings in a well lit area.
Right now I am having an odd problem with the RIO talking to the arduino. Whenever I run the labview code on my computer it works as intended but when I run it on the RIO it seems the RIO is writing to the serial port several times every time I tell it to write once. I double checked with the arduino sketch below and it seems to confirm that the RIO is writing several times every time the VISA write VI executes while the computer only writes once as intended.
Arduino:
void setup() {
  // put your setup code here, to run once:
delay(2000);
void loop() {
static String C = "wait\n";
    Serial.print(C);
#banthebag
#RIBMEATS
Unread 28-11-2016, 10:00
Bpk9p4's Avatar
Bpk9p4 Bpk9p4 is offline
FRC #1756
Bpk9p4 is on a distinguished road
nice work. Is there any reason you chose this method or i2c
2015 Midwest Regional Finalist
2015 Central Illinois Regional Winner
2015 Newton Division Finalist
2015 Newton Quality Award
Unread 28-11-2016, 10:35
jman4747's Avatar
AKA: Josh
Team Role: CAD
One is how easy the wiring is:
Plug in provided ribbon cable (Pixy to Arduino)
Plug in USB cable (Arduino to RoboRIO)
It's basically impossible for that set up to go wrong.
I also find that rs-232 style serial communication is (was...) very easy to wrap my head around.
Has anyone else tested this by the way?
#banthebag
#RIBMEATS
Unread 28-11-2016, 10:55
AKA: Rohit Gondi
Team Role: Driver
Rookie Year: 2015
I am about to after school today.
