Go to Post Now, everyone knows that Oompaloompas are like bunnies in that they have an insatiable desire to multiply, and the same can be said with Michigan teams (with all due respect) which are currently multiplying and filling that hand-shaped democratic kingdom with their honorable number. - Eugenia Gabrielov [more]
Unread 23-11-2016, 23:36
Brainiac33 Brainiac33 is offline
FRC #1533
Brainiac33 has a spectacular aura aboutBrainiac33 has a spectacular aura aboutBrainiac33 has a spectacular aura about
Strange Swerve 4.0 Triple Strange 1533
Introducing, Strange Swerve 4.0!
This summer our team designed and created our fourth swerve iteration in preparation for next year's challenge! We have managed to use swerve in the past two game challenges and hope to continue. Strange Swerve 4.0 is lighter, and more robust than our previous 2016 design, weighing in at 5.4lbs per module. For comparison, in our previous modules, our motors alone weighed in at 4.1lbs. Our design is using mainly water cut parts, one of which is a custom 100 tooth gear. We have an encoder on both our rotation and drive motors. The rest is standard vex gears, gearboxes and wheels. Here are some pictures of the module:
Going a little more technical, our main plate is sandwiched by the 100 tooth gear and a top plate, all of these parts have grooves designed to hold bearings. This allows us to continuously rotate our wheel on the custom bearing. Here are some of the renders from our 3D step models that we will release soon, as we fully intend on using them in 2017.
Comments, feedback, and questions are welcome! You can help us brainstorm some improvements for our design if you wish, or we can explain something on our module more in depth.
Unread 23-11-2016, 23:46
frcguy's Avatar
frcguy frcguy is offline
Unregistered Unuser
AKA: Nicholas Dal Porto
FRC #5940 (B.R.E.A.D.)
Team Role: Tactician
frcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond repute
Re: Strange Swerve 4.0 Triple Strange 1533
Very cool. Is there any way we can get the CAD?
2016: Team 5940 (Silicon Valley Regional Rookie All-Star and Quarterfinalist, Curie Quarterfinalist)
Volunteer: 2016 (Chezy Champs Field Reset, Capital City Classic FTA, MadTown ThrowDown FTA)
Unread 23-11-2016, 23:54
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Very cool! There's so many things I love about this module!
1. Waterjet everything!
2. lightweight!
3. Compact!
4. Double custom ball bearing!
5. Versawheels!
6. Low profile!
Very good job, and I hope I can see it in action next year.
How is the single reduction VP + 100 tooth gear working out? It looks like you're running something close to 10:1 x 100:36, which ends up around 576 rpm, which is very fast for a swerve module. I would change to a 2-stage VP, but that's about the only way I could see this die. The 100 tooth custom gear seems like extra work when you could use an 84t gear instead, but you seem to have good use of the extra space.
The only thing I can see bad about this in the long run is that it might be difficult to integrate a CIM into it, unless you weld a 3/8" hex onto the output shaft for the bevel gear.
I would love to see the CAD for this, if you're willing to part with it.
Unread 23-11-2016, 23:56
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is offline
Looks awesome! How are you making the groove in the gear for the ball bearings?
Unread 24-11-2016, 00:07
ahartnet's Avatar
ahartnet ahartnet is offline
AKA: Andrew Hartnett
FRC #5414 (Pearadox)
ahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant future
very cool design in a lot of ways. I like the plate being sandwhiched with the grooves for bearings.
I'm sure someone will chime in and tell me I'm wrong - and maybe y'all have tested it and can tell me I'm wrong...but I wouldn't want to use the 775pros for a drive motor. If you get in a pushing match or need to play defense you'll risk burning a motor or at least decreasing its life span. At least with the new VPv2's it could be a quick change out - but I wouldnt risk it personally.
Team 451 The Cat Attack, Student Alumni (2005)
Team 1646 Precision Guessworks, Mentor (2006-2008)
Team 2936 Gatorzillas, Mentor (2011-2014)
Team 5414 Pearadox, Mentor (2015-Present)
Last edited by ahartnet : 24-11-2016 at 00:10. Reason: I see the VP encoder now, and that what I thought was an encoder is just the nut
Unread 24-11-2016, 00:10
cad321 cad321 is offline
Jack of all trades, Master of none
AKA: Brian Wagg
FRC #2386 (Trojans)
cad321 is just really nicecad321 is just really nicecad321 is just really nicecad321 is just really nice
What would prevent them from using a CIM on the current VP using the adapter sold by VEXPro?
Unread 24-11-2016, 00:15
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
That's a really good solution, apart from increasing the height of the module a bit.
Unread 24-11-2016, 01:54
dmpage318 dmpage318 is offline
FRC #1533 (Triple Strange)
dmpage318 is an unknown quantity at this point
Both VP gearboxes will likely have a second stage added once we get all the modules together. We just put in single 10:1's for initial testing and you're right, it's EXTREMELY fast.
Unread 24-11-2016, 03:46
Noudvanbrunscho's Avatar
Noudvanbrunscho Noudvanbrunscho is offline
Scout mentor
FRC #4481
Noudvanbrunscho is a jewel in the roughNoudvanbrunscho is a jewel in the roughNoudvanbrunscho is a jewel in the rough
Very very nice, reminds me of the module from 696 in 2015.
I have a question about your gears, are they custom made or where did you buy them?
And what is the total weight of the module?
2015 - Team Spirit Award (Tesla-Archimedes Division)
2015 - Engineering Inspiration (Virginia)
2015 - Finalist (Virginia)
2014 - Imagery Award (Newton Division)
2014 - Engineering Inspiration (North-Carolina)
2013 - Rookie All-Star (North-Carolina)
Forty fooouuuuurrrr --- Eighty ooooooonnnnneeee!
Unread 24-11-2016, 03:52
Originally Posted by Brainiac33 View Post
...weighing in at 5.4lbs per module...
...Our design is using mainly water cut parts, one of which is a custom 100 tooth gear. We have an encoder on both our rotation and drive motors. The rest is standard vex gears...
Unread 24-11-2016, 07:14
Scout mentor
FRC #4481
Originally Posted by Cothron Theiss View Post
Ooh oops, missed that part, went directly for the photo's. Thanks!
Unread 24-11-2016, 07:41
iyportne's Avatar
iyportne iyportne is offline
Head Coach
iyportne is on a distinguished road
Grooves in all plates made the same way. Mount plates on fixture in lathe and use a 1/4" Dia parting tool to cut out groove.
https://youtu.be/vE3397650W4
2016 | NC District Awards - Creativity x2, Industrial Design, Innovation in Control
2016 | NC District - Campbell University Winner, District Championship Winner, THOR Winner
2016 | Carson/Galileo - Creativity Award
Unread 24-11-2016, 07:55
iyportne's Avatar
Head Coach
Nothing...the plan was to make a perfectly scalable module..the power choices and ratios are now all in the versa gearbox, not the mechanical structure. Everything from lightweight and lightning fast to slow and powerful.
I know we'll never win the CD debate about Swerve vs. WCD...but let me just say if you are designing Swerve for pushing matches, you're kinda' missing the whole point anyway.
Unread 24-11-2016, 08:13
iyportne's Avatar
Head Coach
...I have a question about your gears, are they custom made or where did you buy them?
Only custom gear is the housing gear. All others are COTS. Note that housing bearing/gear design would be scalable to any turret, turn-table or arm pivot and prevent those frustrating (yet awesome to look at) sheared gearbox shafts.
Unread 24-11-2016, 09:48
marshall's Avatar
marshall marshall is offline
FRC #0900 (The Zebracorns)
Well done!
