| Thread Tools |
Rating:
Display Modes |
#16
Re: Strange Swerve 4.0 Triple Strange 1533
Fantastic. We've been toying with swerve all summer (mostly in design) and it didn't turn out this slick.
I think elegant is the term to use (as in an elegant solution). |
#17
One question for you, why did you decide not to use the VersaPlanetary encoder for the turning motor?
#18
I'm not on the team but it's a 1:1 ratio the way they have it setup now. Using the encoder block would result in a ratio that is not 1:1 and would then make for some complex math and silliness to figure out the angle of the module.
#19
The cage problem (if it is a problem) would be easy to solve. Just make sure every second ball is smaller. The smaller balls will act as spacers, and since they won't contact both races, they can turn in the opposite direction as the larger balls, eliminating rubbing. Bearing balls are available in increments as small as 1 thousandth of an inch. You can even use plastic balls, since they won't be load bearing. |
#21
Right...the code library is based on absolute position. The encoder is a TT Electronics/BI 6127V1A360L.5FS from Digikey, a linear angle position sensor, makes the code robust and the bot powers up knowing the wheel angles. Of course, the mechanical challenge has always been to get the encoder to match the rotation of the swerve module, but they got that down now after a couple of design interations.
#22
That swerve looks dope. ~22lbs for a swerve is insane.
#24
Thank you, I must have missed that.
#25
Also, this may just be the angle, but the teeth on your watercut gear look more shallow than the teeth on the VexPro gear. Is this just a trick of the light, a mistake in the manufacturing, or did you use a slightly different profile from what's on the VexPro gears? |
#26
Here is the link for the Strange Swerve CAD MODELS!!!
https://grabcad.com/library/strange-swerve-4-0-1 |
#28
And the VersaPlanetaries v2 arrived just in time to swap out all the burned out 775 Pros!
Kidding aside, I'll be intrigued to see how the 775s hold up should this make it to the competition field. Pushing matches aren't the only time a drivetrain could experience high current situations, nor are they always entirely avoidable (especially in games with designated scoring areas and/or chokepoints). I'll also be interested with regards to how the modules hold up to side loads on the wheels. This is a very aggressively packaged module, and it has custom bearings to boot. I'm wondering how well those bearings will deal with scrub forces on the wheels, and what potential there is for those forces to get passed even further up the module. Certainly a very ambitious and advantageous take on a swerve module. Last edited by Lil' Lavery : 11-26-2016 at 10:38 PM. |
#30
Just now noticed that it's a 1/4" bolt serving as the axle. That seems a little thin to me, but if it works, that'll be great.
