Go to Post Dear CNN, We're not from indiana. Love, Wildstang - AlecMataloni [more]
Unread 24-11-2016, 09:59
SenorZ's Avatar
SenorZ SenorZ is offline
Physics Teacher
AKA: Tom Zook
FRC #4276 (Surf City Vikings)
SenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond repute
Re: Strange Swerve 4.0 Triple Strange 1533
Fantastic. We've been toying with swerve all summer (mostly in design) and it didn't turn out this slick.
I think elegant is the term to use (as in an elegant solution).
2013-present: FRC Team 4276, Surf City Vikings
2011-2012: FRC Team 3677, The Don Bots
Unread 24-11-2016, 10:29
Type's Avatar
Type Type is offline
FRC #3452 (GreengineerZ)
Rookie Year: 2016
Type is an unknown quantity at this point
One question for you, why did you decide not to use the VersaPlanetary encoder for the turning motor?
3452- Lead Builder/ Pit Boss & Ambassador
*My posts do not reflect the opinion of my team*
Unread 24-11-2016, 10:40
marshall's Avatar
marshall marshall is offline
FRC #0900 (The Zebracorns)
I'm not on the team but it's a 1:1 ratio the way they have it setup now. Using the encoder block would result in a ratio that is not 1:1 and would then make for some complex math and silliness to figure out the angle of the module.
Unread 24-11-2016, 11:01
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is offline
Originally Posted by Noudvanbrunscho View Post
Ooh oops, missed that part, went directly for the photo's. Thanks!
Haha, those are some great pictures to look at. The last bit of text was easy to miss.
Originally Posted by iyportne View Post
Grooves in all plates made the same way. Mount plates on fixture in lathe and use a 1/4" Dia parting tool to cut out groove.
https://youtu.be/vE3397650W4
Oh wow, that's exactly what I was wondering. That looks great! What's the actual diameter on the ball bearings? I know in commercial bearings, the inner and outer races are cut into a concave path so that the balls automatically center in the path. What made you choose to do use parting cutter? It'd be easy to hold tight tolerances on the depth with, but it'd leave a flat bottom in the groove. Are you guys seeing any issues with the balls catching or jamming since they can move side to side relative to each other and since you don't have an inner cage?
Unread 24-11-2016, 11:13
nuclearnerd's Avatar
nuclearnerd nuclearnerd is offline
Speaking for myself, not my team
AKA: Brendan Simons
FRC #5406 (Celt-X)
nuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant future
I'd be more worried about the balls brinelling such a soft race. I'd love to hear how this design fares over a large amount of use.
The cage problem (if it is a problem) would be easy to solve. Just make sure every second ball is smaller. The smaller balls will act as spacers, and since they won't contact both races, they can turn in the opposite direction as the larger balls, eliminating rubbing. Bearing balls are available in increments as small as 1 thousandth of an inch. You can even use plastic balls, since they won't be load bearing.
Unread 24-11-2016, 11:23
iyportne's Avatar
iyportne iyportne is offline
Head Coach
FRC #1533 (Triple Strange)
iyportne is on a distinguished road
Right...the code library is based on absolute position. The encoder is a TT Electronics/BI 6127V1A360L.5FS from Digikey, a linear angle position sensor, makes the code robust and the bot powers up knowing the wheel angles. Of course, the mechanical challenge has always been to get the encoder to match the rotation of the swerve module, but they got that down now after a couple of design interations.
2016 | NC District Awards - Creativity x2, Industrial Design, Innovation in Control
2016 | NC District - Campbell University Winner, District Championship Winner, THOR Winner
2016 | Carson/Galileo - Creativity Award
Unread 24-11-2016, 11:42
iyportne's Avatar
Head Coach
...What's the actual diameter on the ball bearings? I know in commercial bearings, the inner and outer races are cut into a concave path so that the balls automatically center in the path. What made you choose to do use parting cutter?...Are you guys seeing any issues with the balls catching or jamming since they can move side to side relative to each other and since you don't have an inner cage?...
The balls are 0.250" DELRIN bearings. The channel depths are 3/32" leaving a 1/16" float gap between plates. The parting tool is actually 0.250 circular arc so the channel is a concave path with nearly full contact with bearing circumference. Running dry there is no apparent bearing-to-bearing interference. The first prototype was cut with CNC Mill using a ball end mill, but that was very slow and produced too much cutter advance ridging perpendicular to ball path.
Unread 24-11-2016, 11:51
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
That swerve looks dope. ~22lbs for a swerve is insane.
FTC Game Announcer / EmCee (2014 - Present) | FRC EmCee (2015 - Present) | FRC Referee (2016)
Academic Student (Forever)
Unread 24-11-2016, 12:35
Type's Avatar
Rookie Year: 2016
Thank you, I must have missed that.
Unread 24-11-2016, 19:40
Ahh, ok. All of that sounds good. I've never used a parting tool with a convex face.
Also, this may just be the angle, but the teeth on your watercut gear look more shallow than the teeth on the VexPro gear. Is this just a trick of the light, a mistake in the manufacturing, or did you use a slightly different profile from what's on the VexPro gears?
Unread 24-11-2016, 21:28
dmpage318 dmpage318 is offline
dmpage318 is an unknown quantity at this point
The teeth are in fact more shallow. They were designed to match the profile of VexPro gears but this is how they turned out from the waterjet. We're not too concerned about it because it won't be under a big load and won't be turning very quickly.
Unread 26-11-2016, 21:18
Brainiac33 Brainiac33 is offline
FRC #1533
Brainiac33 has a spectacular aura aboutBrainiac33 has a spectacular aura aboutBrainiac33 has a spectacular aura about
Here is the link for the Strange Swerve CAD MODELS!!!
https://grabcad.com/library/strange-swerve-4-0-1
Unread 26-11-2016, 21:28
frcguy's Avatar
frcguy frcguy is offline
Unregistered Unuser
AKA: Nicholas Dal Porto
FRC #5940 (B.R.E.A.D.)
Team Role: Tactician
frcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond repute
Awesome! Excited to take an in-depth look.
2016: Team 5940 (Silicon Valley Regional Rookie All-Star and Quarterfinalist, Curie Quarterfinalist)
Volunteer: 2016 (Chezy Champs Field Reset, Capital City Classic FTA, MadTown ThrowDown FTA)
Unread 26-11-2016, 22:25
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
And the VersaPlanetaries v2 arrived just in time to swap out all the burned out 775 Pros!
Kidding aside, I'll be intrigued to see how the 775s hold up should this make it to the competition field. Pushing matches aren't the only time a drivetrain could experience high current situations, nor are they always entirely avoidable (especially in games with designated scoring areas and/or chokepoints).
I'll also be interested with regards to how the modules hold up to side loads on the wheels. This is a very aggressively packaged module, and it has custom bearings to boot. I'm wondering how well those bearings will deal with scrub forces on the wheels, and what potential there is for those forces to get passed even further up the module.
Certainly a very ambitious and advantageous take on a swerve module.
Unread 26-11-2016, 22:54
Just now noticed that it's a 1/4" bolt serving as the axle. That seems a little thin to me, but if it works, that'll be great.
