Robostangs 548 2016 Offseason Rocker- Z6
![]() ![]() Full Size Render Full Size Photo The Robostangs present Z6! Another generic chassis with the following:
Re: Robostangs 548 2016 Offseason Rocker- Z6
Interesting Chassis! I am a bit curious as to what its intended purpose is though.
The only reason I could think of to use what appears to be thin polycarbonate on the side plates (and nowhere else) and to arrange the drive the way it is would be for a demonstrator of some kind. Care to elaborate? |
What are the perceived benefits of using polycarbonate for the plates? It looks like you're relying heavily on two zip ties to hold everything together.
The choice to use lexan was an experiment to see how durable the lexan would be and to see if we could shave some weight off the drive base. Plus it looks cool.
We ended up switching to matching aluminum sideplates after our 2016 robot trampled this little guy at an outreach event. I think with the protection of bumpers it is worth using lexan to shave off some weight during the season. |
Don't get me wrong, I don't have a problem with using polycarbonate (we've used it extensively throughout our chassis for years) but it looks like you're using maybe 1/8" at the most?
On our drive system we use 3/8" polycarbonate for durability. Granted we're not bending flanges into it, but I personally don't think I would ever use less than 1/4" thick on a chassis. Polycarbonate is roughly 44% the weight of 6061 aluminum so you do still save weight even with twice the material thickness compared to a typical aluminum frame. Additionally, if you use thicker polycarbonate, you could potentially replace even more of the aluminum frame with polycarbonate like the interior plates that you mounted the gearboxes to. I think I would still leave the front and back parts aluminum though for rigidity. The other trick we've found is it has to be supported with standoffs and such otherwise you get too much flex between attachment points (as it seems you experienced). |
#7
Polycarbonate is a neat building material; it has a lower density than aluminum, but is much more flexible. It has some good applications, but I don't think that replacing aluminum channels in a drivetrain is usually one of them.
Being lighter isn't always the best attribute. Sometimes you need a material that is stiffer rather than lighter.That said, it's great to see you built the design and tested it, that's worth way more experience than just hearing people on Chief Delphi say "that won't work very well". Kudos for that! The zip tie bearing retainers are great, I highly approve of that fix. |
#8
Looks great! Few questions though. How are you bending the lexan? I'm always curious about the different ways people manipulate the stuff. Also, is there any reason you made the 2nd level of the belly pan out of aluminum instead of lexan? That seems like a perfect application for it.
As far as using the lexan for sideplates, I think you'd do well to add some standoffs in between your side plates. They'd support and strengthen the plates much more than the zipties, and in both directions as well. Also, when relying on bends in sheet metal or lexan or paper, the length and bend angle of the flange is important. In the middle of the top bend in the plate closest to the viewer, your flange seems to be flexing upwards such that the bend angle is greater than 90 degrees. This will not impart as much rigidity to the plate as a 90 degree bend, so don't expect it to. |
#9
