Go to Post good to have you on board the Circus Train Jane - Wayne C. [more]
Unread 24-11-2016, 23:49
jnicho15's Avatar
jnicho15 jnicho15 is offline
AKA: Dan
FRC #0548 (Robostangs)
Team Role: Electrical
jnicho15 is just really nicejnicho15 is just really nicejnicho15 is just really nicejnicho15 is just really nice
Robostangs 548 2016 Offseason Rocker- Z6
Full Size Render Full Size Photo
The Robostangs present Z6! Another generic chassis with the following:
  • 6 Wheels! (that don't all touch the ground at once like our comp bot)
  • Lexan Side Plates! (remember to make sure the bearings can't fall out)
  • Flanges! (FYI: cold-bent lexan cracks)
  • Multi-Level Belly Pan!
  • 4-CIM Drive!
  • Dual-Reduction Versa Gearboxes! (9.52:1)
  • Finite-position Chain Tensioners!
  • A roboRIO!
  • A Battery!
Download SOLIDWORKS CADs!
2014: MIHOW DCA, Finalist
2015: MISOU Finalist; MILIV DCA, Winner; MIBED Winner; MICMP Winner, Engineering Excellence
2016: MISOU KPCB Entrepreneurship Award; MILIV DCA; MICMP 16th Alliance- 8-F winner
Unread 25-11-2016, 04:32
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #5712 (Gray Matter)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
Re: Robostangs 548 2016 Offseason Rocker- Z6
Interesting Chassis! I am a bit curious as to what its intended purpose is though.
The only reason I could think of to use what appears to be thin polycarbonate on the side plates (and nowhere else) and to arrange the drive the way it is would be for a demonstrator of some kind.
Care to elaborate?
Unread 25-11-2016, 09:42
jnicho15's Avatar
AKA: Dan
Care to elaborate?
Every offseason, we design and build a simple chassis in order to give design and machining kiddos practice. Them we drive it around at outreach events. This time, we tried lexan sideplates for fun. Also, we may use this design as our drive base in the season.
Unread 25-11-2016, 11:32
tickspe15's Avatar
tickspe15 tickspe15 is offline
Purdue University
AKA: Spencer Tickman
FRC #1747 (Harrison Boiler Robotics)
tickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant future
What are the perceived benefits of using polycarbonate for the plates? It looks like you're relying heavily on two zip ties to hold everything together.
Team 1318: 2011-2015
Team 1747: 2015-Present
NAR (VEX U): 2015-Present
Unread 25-11-2016, 14:05
BigHorse BigHorse is offline
AKA: Hersh
BigHorse has a spectacular aura aboutBigHorse has a spectacular aura aboutBigHorse has a spectacular aura about
The choice to use lexan was an experiment to see how durable the lexan would be and to see if we could shave some weight off the drive base. Plus it looks cool.
We ended up switching to matching aluminum sideplates after our 2016 robot trampled this little guy at an outreach event.
I think with the protection of bumpers it is worth using lexan to shave off some weight during the season.
Unread 25-11-2016, 23:35
cbale2000's Avatar
AKA: Chris Bale
Don't get me wrong, I don't have a problem with using polycarbonate (we've used it extensively throughout our chassis for years) but it looks like you're using maybe 1/8" at the most?
On our drive system we use 3/8" polycarbonate for durability. Granted we're not bending flanges into it, but I personally don't think I would ever use less than 1/4" thick on a chassis. Polycarbonate is roughly 44% the weight of 6061 aluminum so you do still save weight even with twice the material thickness compared to a typical aluminum frame.
Additionally, if you use thicker polycarbonate, you could potentially replace even more of the aluminum frame with polycarbonate like the interior plates that you mounted the gearboxes to. I think I would still leave the front and back parts aluminum though for rigidity.
The other trick we've found is it has to be supported with standoffs and such otherwise you get too much flex between attachment points (as it seems you experienced).
Unread 26-11-2016, 00:28
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
Polycarbonate is a neat building material; it has a lower density than aluminum, but is much more flexible. It has some good applications, but I don't think that replacing aluminum channels in a drivetrain is usually one of them. Being lighter isn't always the best attribute. Sometimes you need a material that is stiffer rather than lighter.
That said, it's great to see you built the design and tested it, that's worth way more experience than just hearing people on Chief Delphi say "that won't work very well". Kudos for that!
The zip tie bearing retainers are great, I highly approve of that fix.
Unread 26-11-2016, 00:58
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is offline
Registered Muser
Cothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond repute
Looks great! Few questions though. How are you bending the lexan? I'm always curious about the different ways people manipulate the stuff. Also, is there any reason you made the 2nd level of the belly pan out of aluminum instead of lexan? That seems like a perfect application for it.
As far as using the lexan for sideplates, I think you'd do well to add some standoffs in between your side plates. They'd support and strengthen the plates much more than the zipties, and in both directions as well.
Also, when relying on bends in sheet metal or lexan or paper, the length and bend angle of the flange is important. In the middle of the top bend in the plate closest to the viewer, your flange seems to be flexing upwards such that the bend angle is greater than 90 degrees. This will not impart as much rigidity to the plate as a 90 degree bend, so don't expect it to.
Unread 26-11-2016, 14:04
jnicho15's Avatar
AKA: Dan
Look closer at the "bearings".
Unread 26-11-2016, 20:21
cbale2000's Avatar
AKA: Chris Bale
Sometimes flexible is good though. Aluminum will deform when it takes an impact which can be difficult to fix without replacing the part, whereas polycarbonate will just flex and return to its original position. That little bit of flex can make a big difference when it comes to frame durability and longevity long-term. Granted, you do still have to make sure it's strong enough to not fail catastrophically during typical use.
