Go to Post Frisbees [as next year's game piece]. That is all. - Frenchie461 [more]
Go Back   Chief Delphi > Technical > CAD
Unread 25-11-2016, 13:06
Joseph DeRoest's Avatar
Joseph DeRoest Joseph DeRoest is offline
FRC #2990 (Hotwire Robotics)
Joseph DeRoest is a jewel in the roughJoseph DeRoest is a jewel in the roughJoseph DeRoest is a jewel in the rough
Graphics Cards for CAD?
Hello, everyone. I have a new computer that I am currently building specifically to run Autodesk Inventor Professional, and am trying to decide on which graphics card to buy. I have set aside $300 specifically for a graphics card and will be buying one on Cyber Monday.
I will gladly appreciate your help.
Unread 25-11-2016, 13:22
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Graphics Cards for CAD?
It really depends on how far you're going to go with it, the type of work you plan to do, and how many pixels you plan to drive. I would argue for simple parts and small to medium assemblies in Inventor, you don't need any graphics card at all. Once you get into moderately complex assemblies, or if you plan to do any CAM simulation in Inventor HSM, then a graphics card is a good idea.
We run Quadro K620s with a single monitor at 2560x1440 and we're pretty happy with the performance there. Only slight hiccups in HSM CAM simulation of advanced paths, but buttery smooth in the CAD environment. You may want to go to a slightly higher spec if you plan on running 4K.
I run a Quadro K2200 across three displays at 1920x1080 and again, buttery smooth, and a bit more smooth in HSM CAM simulations than the Quadro K620.
The Quadro K1200 and M2000 are also out now, with the M2000 being about the best card within your budget, by my guess is that's pretty overkill for whatever you're going to be doing. Most people who do this for a living are not even running that high spec of a card. But hey, I don't know, maybe you have a need to do CAD on four 4k monitors at the same time....
My advice, save a little on the graphics card, and use whatever you save to go for a nicer monitor. Working at 2560x1440 on a 27 inch is nice. I run a Dell U2715H that I'm happy with except for the issue where it doesn't wake on a mouse jiggle with Windows 7. The HP Z27 series monitors are also nice.
You may even consider a 34" 3440x1440 Ultrawide. The prices are down to about $500.
Finally, Inventor does work well with gaming-oriented cards, but the drivers are not tested/certified, and I have no first-hand knowledge of it. Here is a list of certified graphics hardware for Autodesk Inventor Professional 2017. AMD FirePro cards are certified and recommended as well and can be more affordable. They worked well when we used to use them, though nVidia is probably a bit more industry standard.
Unread 25-11-2016, 13:54
Sanddrag,
To answer some of your questions, I will definitely be using CAM software, as my team recently bought a 3-axis CNC router. I am currently looking at 1080p resolution. The CAD drawings that I plan to draw will be of medium complexity (at least a couple hundred parts), and I will be using the software on a regular or daily basis.
Thanks for your help, good sir! Your advice is duly noted.
Unread 25-11-2016, 14:54
Conor Ryan Conor Ryan is offline
I'm parking robot yacht club.
FRC #4571 (Robot Yacht Club)
Conor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond repute
Make sure you have enough RAM. 16 gigs is probably where the sweet spots start for medium sized assemblies. Check out some of the specs in the Dell Precision desktop workstation series, those are the most commonly used in industry.
Unread 26-11-2016, 11:39
dirtbikerxz's Avatar
dirtbikerxz dirtbikerxz is offline
Captain | Driver | CAD | Junior
AKA: Rohit Gondi
FRC #3991 (KnightVision)
Team Role: Driver
Rookie Year: 2015
dirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud of
Joseph, I know this isn't the point of this thread. But have you chosen a CPU yet? Sometimes if you are on a budget, spending more on the CPU may be more beneficial than spending more on the GPU for CAD.
Team 3991: Driver since freshman (2015-), Captain since sophomore (2016-), CADer
"The human condition is not perfect. We are not perfect specimens, any of us. We're not robots." - Michael Ovitz
My posts may or may not reflect the views of my team, they are my opinions, and mine alone.
Unread 26-11-2016, 11:51
Michael Hill's Avatar
Michael Hill Michael Hill is online now
This is true. Also, since most CAD software will not make assembly/part calculations in parallel, hyperthreading doesn't really help. However, rendering will benefit from good GPU performance.
I'd also check out this article: http://www.enginoor.com/solidworks-pc-2017/
Unread 26-11-2016, 12:41
AKA: Rohit Gondi
Team Role: Driver
Rookie Year: 2015
Just a heads up. That article is suggesting using a intel i7-6700k on a z97 motherboard...... A 6700k will not run on a z97. It a different socket type. You need a z170 motherboard.
Unread 26-11-2016, 13:09
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #5712 (Gray Matter)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
To be honest it doesn't take much to run CAD/CAM comfortably. I personally am using an nVidia GTX 970 on my desktop at home to run Inventor, but I have also run it on a GTX 760 and 480 in the past with no significant issues. I also run Inventor on my laptop which has a Radeon HD 8650G + 8670M Dual graphics setup on it and, while not quite as smooth as my desktop, runs just fine with only minimal performance loss.
By in large, while graphics are important to CAD, it seems that most programs are more CPU and RAM dependent then they are graphics. That said, I do always recommend people watch these two videos when shopping for a graphics card for any purpose:
https://www.youtube.com/watch?v=sph6cjJeRdI
https://www.youtube.com/watch?v=xp6ltBCMDCE
Unread 26-11-2016, 13:30
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Just get the cheapest Quadro you can find. It'll work great. Any current Quadro>>$1,000 Titan X gaming card.
2001-2004: Team 100
2006-Present: Team 254
Unread 28-11-2016, 17:53
Thank you all for your help! I appreciate all your advice.
I have a Skylake i7 installed.
I'm curious as to how so. I've been told that a recent GTX card would run CAD just fine.
Unread 28-11-2016, 19:30
cgmv123's Avatar
cgmv123 cgmv123 is online now
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Gaming graphics are (essentially) no better than integrated graphics for CAD. If you're spending money on a graphics card for CAD, you want a workstation graphics card that will actually improve the CAD software's performance.
Unread 28-11-2016, 20:30
Cory's Avatar
AKA: Cory McBride
You're not wrong. Any recent one would be fine. It's just that the cheapest quadro card is way better.
A $160 Quadro K620 will beat the pants off of every GTX card on the market when running Solidworks in shaded with edges mode (which is my preferred mode and I assume the preferred mode of most).
At 1080p a $1000 12 GB Titan X is 33% worse than the $160 K620.
You can see a more detailed breakdown here
[edit]: I didn't read that Inventor was the choice here. Dave's comments below are probably pretty relevant, especially if it will be a computer for mixed use (CAD/gaming). I'm sure you can find similar comparisons to the one I linked above for Inventor performance.
2001-2004: Team 100
Unread 28-11-2016, 20:59
As a note, Inventor will likely perform substantially better with gaming-oriented cards than Solidworks will. It is my understanding that Solidworks uses OpenGL graphics which runs better on workstation-class cards (Quadro, Firepro) and not as well on gamind cards (Geforce, Radeon).
Inventor is built to run on DirectX graphics, which can run well on gaming cards as well as workstation cards.
However, I suspect that any CAD program will run better on a workstation card than on a gaming card. Whether or not you as the user will directly notice it? That's another story.
Disclaimer: Do your own research. I do not have first-hand recent knowledge with SolidWorks nor Geforce cards.
Unread 28-11-2016, 21:11
frcguy's Avatar
frcguy frcguy is offline
Unregistered Unuser
AKA: Nicholas Dal Porto
FRC #5940 (B.R.E.A.D.)
Team Role: Tactician
frcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond repute
I know this thread is mainly about Inventor, but after seeing Cory's post I thought I'd share a bit of experience I have.
We did a little comparison between our CAD workstation with a Quadro 600 (released in 2010), and my home desktop with a Radeon R9 380X (released in 2015). Both systems are identical with the only difference being the GPU. Running the Solidworks built-in performance benchmark, the system with the Quadro can beat my system with the gaming GPU every time in terms of GPU performance.
Goes to show that the system with the 6 year old Quadro can easily eclipse a modern and fairly current gaming card.
2016: Team 5940 (Silicon Valley Regional Rookie All-Star and Quarterfinalist, Curie Quarterfinalist)
Volunteer: 2016 (Chezy Champs Field Reset, Capital City Classic FTA, MadTown ThrowDown FTA)
Unread 29-11-2016, 00:54
You read my mind. I will be using my computer as a multi-use computer.
After doing some more research (Autodesk forums, etc.), it seems as if a GTX 1060 6GB may be able to suffice.
