Go to Post The only shame is if you are too proud to ask for help and to learn. - Mc Kenna [more]
Unread 26-11-2016, 20:21
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #0703 (Phoenix)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
Re: Robostangs 548 2016 Offseason Rocker- Z6
Originally Posted by s_forbes View Post
Polycarbonate is a neat building material; it has a lower density than aluminum, but is much more flexible. It has some good applications, but I don't think that replacing aluminum channels in a drivetrain is usually one of them. Being lighter isn't always the best attribute. Sometimes you need a material that is stiffer rather than lighter.
Sometimes flexible is good though. Aluminum will deform when it takes an impact which can be difficult to fix without replacing the part, whereas polycarbonate will just flex and return to its original position. That little bit of flex can make a big difference when it comes to frame durability and longevity long-term. Granted, you do still have to make sure it's strong enough to not fail catastrophically during typical use.
