Go to Post Remember, however, that such software limitations in no way approximate the functionality of a multiple-speed, mechanical transmission. They're simply a convenient way of limiting your students' lead feet. - Madison [more]
  #31   Spotlight this post!
Unread 26-11-2016, 23:06
dmpage318 dmpage318 is offline
FRC #1533 (Triple Strange)
dmpage318 is an unknown quantity at this point
Re: Strange Swerve 4.0 Triple Strange 1533
Originally Posted by Cothron Theiss View Post
Just now noticed that it's a 1/4" bolt serving as the axle. That seems a little thin to me, but if it works, that'll be great.
You can't see it because of the spacers, but the bolt passes through a 1/2" aluminum tube.
  #32   Spotlight this post!
Unread 04-12-2016, 13:52
Brainiac33 Brainiac33 is offline
FRC #1533
Brainiac33 has a spectacular aura aboutBrainiac33 has a spectacular aura aboutBrainiac33 has a spectacular aura about
We have just finished assembling all four of the modules, and have them mounted to a base chassis. The final weight is 25.2 lb. for all four modules AND our base chassis. Just as a heads-up, we will be giving a presentation on swerve mechanics, design, and programing at the FIRST North Carolina FRC workshop at NCSSM on December 17th so join us if you can. In the meantime, here are some more pictures of our design!
  #33   Spotlight this post!
Unread 05-12-2016, 14:35
OccamzRazor's Avatar
OccamzRazor OccamzRazor is offline
Go YETI!
AKA: Robbie
FRC #3506 (YETI)
OccamzRazor is a splendid one to beholdOccamzRazor is a splendid one to beholdOccamzRazor is a splendid one to beholdOccamzRazor is a splendid one to beholdOccamzRazor is a splendid one to beholdOccamzRazor is a splendid one to behold
This looks pretty compact and quite a bit easier to repair compared to what you had on the last robot. What was the overall weight of the last system minus the tank treads and whatnot?
What kind of power savings do you expect from the changes?
Can't wait to see this one at the workshop in Durham.
2015 NC Regional Chairman's Award
2016 NC Guilford District Event Winner
2016 NC Guilford District Chairman's Award
2016 NC District Championship Winner
2016 NC Regional Chairman's Award
2016 NC Woodie Flowers Award Finalist - Lia Schwinghammer
  #34   Spotlight this post!
Unread 07-12-2016, 18:05
Bennett548 Bennett548 is offline
Engineering Mentor
AKA: Steve Bennett
FRC #0548 (Robostangs)
Bennett548 is just really niceBennett548 is just really niceBennett548 is just really niceBennett548 is just really nice
Have you had a chance to run this under load?
My concern is that the axial force of the bevel gears has to travel all the way thru the churro standoffs, thru the delrin bearings, and then up the plates holding the bearings. I would imagine the bevel gears will push away from each other quite a bit, which greatly reduces the efficiency and will wear down the gears much faster than normal.
I would suggest taking the plates that carry the horizontal bevel shaft bearing and extend them upwards, screw in a cross plate and put in a bearing that rides on the 3/8" hex shaft output of the versaplanetary. That way the axial force of the bevel gears won't push them apart very much.
Otherwise it is very cool. Put up some videos when you start driving!
  #35   Spotlight this post!
Unread 19-12-2016, 08:14
iyportne's Avatar
iyportne iyportne is offline
iyportne is on a distinguished road
It's alive! Strange Swerve 4.0 made its first public appearance at the 2016 NC FRC Workshops.
https://youtu.be/VbXx9Hj13eI
Base as seen weighs in at 34.6 lb without battery.
2016 | NC District Awards - Creativity x2, Industrial Design, Innovation in Control
2016 | NC District - Campbell University Winner, District Championship Winner, THOR Winner
2016 | Carson/Galileo - Creativity Award
  #36   Spotlight this post!
Unread 19-12-2016, 14:54
ToddF's Avatar
ToddF ToddF is offline
mechanical engineer
AKA: Todd Ferrante
FRC #2363 (Triple Helix)
ToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond repute
We've been looking for a swerve module buildable with our resources. Our swerve drive project has been on hold until we got access to a CNC machine. With this being waterjet cut, we finally have a viable path to building our own swerve modules. I think we've got our next summer development project. I can't wait to see how this holds up in competition.
Todd F.
mentor, FIRST team 2363, Triple Helix
Photo gallery
video channel
Triple Helix mobile
  #37   Spotlight this post!
Unread 19-12-2016, 15:27
FRC #1533
During our build process, we tried to stay as organized and precise as possible, we made these layouts at a 1:1 scale with the actual pieces just so we had layouts of all our parts.
Here is a google docs link to a much higher-res pdf if thats easier to download and use.
https://drive.google.com/open?id=0B4...3hrcTJWa1AyTlE
  #38   Spotlight this post!
Unread 27-12-2016, 19:17
FRC #1533
In order to make swerve even more accessible for any team, we wanted to make our code public and available for anyone to use on their prototypes and designs. Here is the link to our github: https://github.com/ecgrobotics/Strange-Swerve
