Go to Post Competition is only the path that FIRST takes to bring science, engineering, and technology to the masses. - Pavan Dave [more]
  #31   Spotlight this post!
Unread 26-11-2016, 16:46
Andrew_L's Avatar
Andrew_L Andrew_L is offline
#DriveSwerveEveryDay
AKA: Drübr Inc.
FRC #1323 (Madtown Robotics) #971 (Spartan Robotics)
Andrew_L has much to be proud ofAndrew_L has much to be proud ofAndrew_L has much to be proud ofAndrew_L has much to be proud ofAndrew_L has much to be proud ofAndrew_L has much to be proud ofAndrew_L has much to be proud ofAndrew_L has much to be proud ofAndrew_L has much to be proud of
Re: VEXpro 2017
Originally Posted by Lil' Lavery View Post
Particularly looking at the WCP gearboxes.
Give it a couple of weeks - I believe RC mentioned something about stock coming in within the next two to three weeks in another thread.
  #32   Spotlight this post!
Unread 26-11-2016, 18:28
Lil' Lavery Lil' Lavery is online now
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Re: VEXpro 2017
We're running out of a "couple of weeks" to give.
  #33   Spotlight this post!
Unread 27-11-2016, 00:37
Andrew_L's Avatar
AKA: Drübr Inc.
Re: VEXpro 2017
What's your deadline? I don't have any inside info, but from previous years most of the suppliers have their stock ready by early to mid December.
  #34   Spotlight this post!
Unread 27-11-2016, 15:19
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: VEXpro 2017
I obviously can't speak for Sean, but we try to have most of our pre-season purchasing done before Thanksgiving, to avoid the December shipping rush. About all we have left are fasteners and metal stock.
  #35   Spotlight this post!
Unread 28-11-2016, 14:38
DRow's Avatar
DRow DRow is offline
VEX Robotics Marketing Coordinator
AKA: Dillon Row
FRC #0148 (Robowranglers)
DRow has a reputation beyond reputeDRow has a reputation beyond reputeDRow has a reputation beyond reputeDRow has a reputation beyond reputeDRow has a reputation beyond reputeDRow has a reputation beyond reputeDRow has a reputation beyond reputeDRow has a reputation beyond reputeDRow has a reputation beyond reputeDRow has a reputation beyond reputeDRow has a reputation beyond repute
Re: VEXpro 2017
Any dates as to when the VexPro line-up will be fully restocked? Particularly looking at the WCP gearboxes.
All products are in work, and we hope to have mostly everything in stock by 12/15, with all items in stock by Kickoff.
Are there any other new products this year?
We appreciate the interest in additional VEXpro items. We consider this product line to be fairly mature. While we talked about a variety of things we could do for 2017, many of these are niche products and don't make sense for us to provide. The VersaPlanetary upgrade is the biggest change for this season. There are some other small things coming out, but due to manufacturing delays we don't know exactly when they'll be available. We're sensitive to the needs of teams, and since we can't guarantee a date we decided it is probably best to just "launch them once they're available" so that no one is depending on them in their design. As these small items roll out, we'll post announcements here.
Team 148
Student (09-11)
Mentor (12-14, 16-?)
  #36   Spotlight this post!
Unread 12-01-2017, 14:11
DRow's Avatar
AKA: Dillon Row
Re: VEXpro 2017
We've added steel versions to several of our VEXpro spur gears in both 1/2" and 3/8" Hex. These are now in stock on the VEXpro website! Use steel gears for high-torque or high shock-load situations, and aluminum gears to save precious weight.
Be sure to check them out here:
http://www.vexrobotics.com/vexpro/mo...-hex-bore.html (1/2")
http://www.vexrobotics.com/vexpro/mo...-hex-bore.html (3/8")
Look for more updates coming soon.
Team 148
Student (09-11)
  #37   Spotlight this post!
Unread 12-01-2017, 15:25
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #5712 (Gray Matter)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
Re: VEXpro 2017
Was there any particular reason you chose those size gears in particular? Any plans to add versahub-compatible versions?
2005-2008: FRC 703 Phoenix - Driver
2009-2016: FRC 703 Phoenix - Mentor
2017-????: FRC 5712 Gray Matter - Mentor
  #38   Spotlight this post!
Unread 12-01-2017, 15:54
Chris is me's Avatar
AKA: Pinecone
Re: VEXpro 2017
My reasonable assumption: The smallest gears are used as pinions more and are more likely to strip than a larger gear.
None of the gears that come in steel are larger than 1.5" pitch diameter, so the VersaKey doesn't have anywhere to go.
