Go to Post Holy cow! Five years in FIRST and it only gets better! Skyway has supplied wheels to FIRST for ten years. Ten years ago Dean called Ken for wheels. Ken said yes. Man, we love helping you guys and gals get good wheels. ;) Bart at Skywaywheels.com - SkywayWheels [more]
View Poll Results: CAN WE USE A N64 CONTROLLER TO CONTROL THE ROBOT????
YES YOU CAN!!!! 16 37.21%
NO YOU CANT!!! 27 62.79%
Voters: 43. You may not vote on this poll
Unread 12-02-2003, 14:50
Joe Matt's Avatar
Joe Matt Joe Matt is offline
Wake Up Get Up Get Out There
Joe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond repute
Originally posted by ronnie_82
Mine team asked FIRST if we can use a controller from playstation and they said no because must video game controllers are not 15 pins
I think the PS controller is digital output (or the old ones are), so that would be out of the question, but if you can make a 15-pin GCN or N64 controller, I would pay you to ship me one and pay for the cost of the controller and conversion.
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
Thats odd because I rember somewhere on another forum someone once said they saw an andvertisement from IFI that said you could use a playstation controller.
Unread 12-02-2003, 18:12
John Bono's Avatar
John Bono John Bono is offline
#0990 (We don't have one :cries:)
John Bono is an unknown quantity at this point
...amount of ignorance...astounding...
Okay:
1) How many analogs there are on a controller shouldn't be the sole source of its selection--the largest consideration should be ease of the conversion to 15 pin.
2) Unless they changed it, there's still that $100 electronics limit that still applies to controls. Keep that in mind if I'm right on that one.
3) Just use a controller designed for 15 pins. My Axis Pad has served me quite well, and should address all of your control issues.
"Proof is King. Logic is Prime Minister." -Force-Attuned Krokoth
"Any fool can make things bigger, more complex, and more violent. It takes a touch of genius--and a lot of courage--to move in the opposite direction." -Albert Einstein
"Never put off until tomorrow what you can do the day after tomorrow." -Samuel Clemens
Unread 14-02-2003, 21:18
jacob_dilles's Avatar
jacob_dilles jacob_dilles is offline
AKA: theshadow
FRC #0620 (WarBots)
jacob_dilles will become famous soon enough
Send a message via AIM to jacob_dilles
If the N64 controler is hard to modify, what about PS2? It only has 9 pins on the connector so I would think that it was digital, but I am just guessing... Does anybody know if it would be possable to use it?
Also, I saw an add once that advertised using a PSX (PS1) controler on a small robot. Would that work?
In both cases I assume that an interface box would have to be built. Any information at all would be helpful... -Jacob
Unread 14-02-2003, 21:47
Duke 13370's Avatar
Duke 13370 Duke 13370 is offline
C is for cookie...
#0862 (Team Lightning)
Team Role: Webmaster
Duke 13370 will become famous soon enough
Send a message via AIM to Duke 13370
Confucius says: "PINS MEAN NOTHING!"
The OI cannot accept data from the following without external cuircutry: any sony playstation controller, any Nintendo controllers, any sega controller created after saturn, xbox, and newer versions of atari.
It can kinda accept the following: old atari (joystick style), older sega controllers. That is it! no more! (at least fromt eh console market)
read my last post, i'm not crazy.
Please note, you can use some of the others, but you would need external custom circutry. And i don't mean some soldering of a couple wires, i mean a small control board at least the size of a playing card, with much design and implementation work. -- Get over it, it doesn't work!
<edit>
neo geo controllers are perfect, they have everything and are simple, you need only do some minor soldering to get them to work.
</edit>
---Lightning Robotics!---
Unread 19-02-2003, 13:01
Steven Carmain Steven Carmain is offline
Bit Twiddler
FRC #2832
Steven Carmain will become famous soon enough
We've thought of using racing wheels for the OI, but it was all digital inputs. My sugestion is not to use any game controller, unless you can find a wiring schematic, especially if you mix up power and ground. Other things you have to do is make a connection system, decode the signal, and make a circut to control the robot. There is no way you can design one now, but offseason you can try.
I found a wiring diagram for a N64 controller here
P.S. I don't think you can use WaveBird controllers because it may interfere with the control system. If you can figure out what the frequency is, and it is not 900 mhz, then talk to First. They will probally say no.
2017 - Team 2832 Mentor
2016 - Team 6013 Mentor
2002-05 - Team 45 Software/Electrical
A robot is like a campfire: it takes a while to bulid it, and then everyone surounds it!
A world without standards is chaos. A world with standards is chaos.
Unread 17-04-2003, 11:59
bethMonster's Avatar
bethMonster bethMonster is offline
#0677 (the Wire Strippers)
bethMonster is an unknown quantity at this point
Send a message via AIM to bethMonster
ddr
i don't know about how you would go about it, but i has to be allowed. i saw a team with a dance dance revolution (for ps1) pad as part of their controls at the cleveland regional.
Unread 17-04-2003, 13:25
My understanding of the rules are this...
Anything you can come up with that is wired through the 15 pin connector is now legal with the stipulation that wiring errors may void the OI warranty. Teams have been getting control awards based on gloves and special mats used for control.
Unread 17-04-2003, 14:43
Caleb Fulton's Avatar
Caleb Fulton Caleb Fulton is offline
Z = Z^2 + C ......WHEEEE!
AKA: aXvXiA
#0461 (West Side Boiler Invasion)
Caleb Fulton has a spectacular aura aboutCaleb Fulton has a spectacular aura aboutCaleb Fulton has a spectacular aura about
Send a message via AIM to Caleb Fulton
All you need for digital inputs to the OI are switches. All you need for analog inputs are 100k ohm potentiometers if you wire them properly. Look at how the controllers are wired and go from there...It would definitely NOT be impossible, especially with older, simpler controllers.
Edit: You could also make your own controller, like we did this year
Unread 17-04-2003, 15:51
Josh Hambright's Avatar
Josh Hambright Josh Hambright is offline
{Error Processing Custom Title}
AKA: oneangrydwarf/jtosh
no team (old school gangsta)
Josh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond repute
Send a message via AIM to Josh Hambright
Rewiring things is fun.... If anyone saw our controls last year we had the cool looking flight sim controls that were completely rewired...or our controls this year that the most standard part of what a modified Y-Cable...everything else was custom wired up in some way
Just make sure whatever you do that you document it thoroughly...I didn't realize it till competition but our trigger and top button on our arm joystick had been switched and we didn't notice it till we tried to have them controlling something!
I'm now working on some ideas for a trackball control! hehe it would be great for a kiwi drive or crap drive type design!
Former 461 Student/Mentor. Former 1272 and 1018 Mentor. Team 1555 Super-Fan.
Science and Engineering Can Open New Doors. --S.E.C.O.N.D.--
Co-Founder IndianaFIRST
Share your FIRST photos on Flickr!
Unread 18-04-2003, 12:48
FRC Key Volunteer Trainer
AKA: CrazyNate
In talking with some of the people from IFI, they have an OI in development which has playstation compatible ports in place of a couple of the 15 pin ports...originally, this past years' CDI was going to be played using EduBots with the new OI, but IFI had some delays in getting the new equipment working(part of why CDI was cancelled this year, from my understanding)...
Nate Smith
nsmith@smythsoft.com
How much planning goes into your robot? Jnadke General Forum 41 29-01-2006 21:29
serious problem found - robot controller resets when jarred! KenWittlief Electrical 23 19-03-2003 13:30
Can We Use A N64 Controller To Control Our Robot??? pobots Rules/Strategy 1 11-02-2003 23:14
RoboCon 1.01 (control robot from PC) rbayer Programming 20 06-11-2002 21:30
about how Drive Train push the robot... shouldn't the force accelerate the robot? Ken Leung Technical Discussion 12 26-11-2001 09:39
