Go to Post The more you cling to the misfortunes that have already befallen you, the less you'll be able move forward from here. - Kevin Sevcik [more]
  #37   Spotlight this post!
Unread 11-28-2016, 02:26 PM
TJP123 TJP123 is offline
AKA: Tom Pospeshil
FRC #0503 (Frog Force)
TJP123 has much to be proud ofTJP123 has much to be proud ofTJP123 has much to be proud ofTJP123 has much to be proud ofTJP123 has much to be proud ofTJP123 has much to be proud ofTJP123 has much to be proud ofTJP123 has much to be proud ofTJP123 has much to be proud of
Re: Inter-District Play in 2017
Originally Posted by IKE View Post
I do not believe there will be a lot of open spots in Michigan unless we add another another event (a couple were added a couple weeks ago). That being said, we are now a large enough organization that we might have some pre-season fallout which could open up a few spots.
Relevant to this thread, the standard 40 team district format with 12 matches requires 80 matches for qualifying (every match counts). Each team added or removed increases or decreases the schedule by 2 matches effectively. With an early season cycle time of likely 7-ish minutes, adding a team basically adds about 15 minutes more towards the qualifying schedule. Later in the season, adding 1 is a bit less impactful as the cycle time tends to get faster with practice and experienced robots.
My fuzzy memory and math skills tell me there will be about 8 extra slots.
456* teams x 2 events = 912 slots needed
23 events x 40 teams = 920 slots
Fuzzy math skills tell me 920 - 912 = 8 extra slots
*Fuzzy memory tells me that was the number Gail gave
