Go to Post We are just here to give back to a program that gave us so much as students. - Alex Cormier [more]
  #31   Spotlight this post!
Unread 28-11-2016, 23:32
GUI GUI is offline
AKA: Gary
FRC #4183 (Bit Buckets)
GUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to behold
Send a message via Yahoo to GUI
Re: pic: 3 wheel omni drive concept
*cough* Why are you only posting screenshots? *cough*
  #32   Spotlight this post!
Unread 28-11-2016, 23:45
s_forbes's Avatar
s_forbes s_forbes is online now
anonymous internet person
FRC #0842 (Falcon Robotics)
Ooh, check out Mr. Spoily McSpoilerpants over here.
  #33   Spotlight this post!
Unread 28-11-2016, 23:47
dirtbikerxz's Avatar
dirtbikerxz dirtbikerxz is offline
Captain | Driver | CAD | Junior
AKA: Rohit Gondi
FRC #3991 (KnightVision)
Team Role: Driver
Rookie Year: 2015
dirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud of
CAAAAAD
Team 3991: Driver since freshman (2015-), Captain since sophomore (2016-), CADer
"The human condition is not perfect. We are not perfect specimens, any of us. We're not robots." - Michael Ovitz
My posts may or may not reflect the views of my team, they are my opinions, and mine alone.
  #34   Spotlight this post!
Unread 29-11-2016, 00:45
Aren_Hill's Avatar
Build Nifty Things
Originally Posted by s_forbes View Post
That's a really good point. Using the toggling style of strafing mechanism is probably a much better application for this, since when it's not in use it leaves the full weight of the robot on the two outside wheels. (I believe this was first used on 148's 2014 robot?) You could probably spend a lot of time playing with the geometry to get it to work just right for a strafing segway robot, since the downforce is dependent on the geometry and how much torque the motor is applying. Would be a fun project!
Yeah, 148's bot in 2014 was the first instance of it, a JVN special (the VEXiq prototype was adorable).
-Aren
A guy who likes robots.
  #35   Spotlight this post!
Unread 29-11-2016, 07:29
GeeTwo's Avatar
GeeTwo GeeTwo is online now
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Originally Posted by z_beeblebrox View Post
... how damage is avoided when the robot tips over (that's a lot of energy that has to be dissipated).
Self righting would be done using a versaplanetary winding a strap to move an arm, one on each side of the robot. The arm would return to it's original position when the strap is let back out, using the magic of springs (more latex).
[image]
A damper to lessen the shock when falling over is a really good idea. I'm not sure where the best place to source parts for something like that would be. Some mountain bike spring/damper sets could be used, since they are lightweight by design. Maybe a simple low force gas strut could work, too.
You may also be able to achieve this by partially deploying the self-righting mechanism, and taking up the shock through backdriving the VP.
I did a white paper on the math of this sort of module about two years ago that may give you a good start. Note that this configuration will take more weight off of the wheel you're strafing away from than the one you're strafing towards; it may be easier to keep the balance routines working with a centered, linearly sprung/actuated strafe module.
  #36   Spotlight this post!
Unread 29-11-2016, 16:07
dtengineering's Avatar
AKA: Jason Brett
Originally Posted by Ari423 View Post
I wasn't saying that wood robots won't work. ... you could see legal wood on metal contact ... and that scares me.
Not wanting to detract from the main point of the thread, because I think the idea is pretty cool and I'd love to see a machine like this play the game on year, but designing with wood actually gives you the ability to create stronger, stiffer manipulators in many cases. The lower density results in a greater specific stiffness, particularly when dealing with solid cross sections.
I know you didn't mean to insult wood... I can see you've planned to use it extensively, but we do have a small but noisy "wood is good" cheering squad here on CD. I've built a few wooden robots and arms where the wood on metal contact wouldn't be scary for the wood structure!
Anyway, cool design. Look forward to seeing it go one day!
Jason
  #37   Spotlight this post!
foote stepped in
AKA: E. Foote
FRC #0868
I always love the discussions these ideas can generate.
This might have done well in 2007, I remember 1501 building a 2 wheel robot that year. Add a few ramps and you've got a nice robot
Be Healthy. Never Stop Learning. Say It Like It Is. Own It.
Like our values? Flexware Innovation is looking for Automation Engineers. Check us out!
  #38   Spotlight this post!
Unread 29-11-2016, 19:48
s_forbes's Avatar
I like the idea of using the self-righting mechanisms as the brake for falling, it gives them multiple functions. I don't think the versaplanetary would like being slammed over and over again though. It probably would need a damping method between the end of the arm and the gearbox, or we would have to invest globs of money into spare versaplanetary stages.
I thought about several ways to implement this, and I think this is one of the better ways. Using a rear mountain bike shock on an additional joint on the self righting arm gives it damping ability, and is pretty adjustable. It looks like some air shocks have the ability to adjust the spring force (by varying the air pressure) and the damping coefficient, so it could likely be optimized to get rid of all of the bouncing after falling over. Pretty nifty!
  #39   Spotlight this post!
Unread 29-11-2016, 19:58
Ari423's Avatar
Ari423 Ari423 is online now
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant future
Is the plan to have the self-righting mechanisms only attached to the chassis through a single cantilevered shaft or is there something else not yet modeled? Because if so, that's a lot of force going through a cantilevered shaft, especially one only attached to a single piece of wood (again, not bashing wood; I would be sceptical with it only going through a single piece of sheet metal too).
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
  #40   Spotlight this post!
Unread 29-11-2016, 20:05
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Taking the issues in reverse order:
Looking at the pics closely (particularly the one in post 15 of this thread), it appears that the shaft mounts through the tubing, not just the plywood.
These could easily become "U" shafts, with the other arm pivoted on the inside of the opposite "upright". If I'm picturing this correctly, each would not interfere with the action of the other. This setup would also support some idle rollers if desired to do things like the low bar in 2016 (Of course, the main drive train would need to be modified to make contact with the carpet when somewhat on its side.)
  #41   Spotlight this post!
Unread 29-11-2016, 20:31
Ari423's Avatar
FRC #5987 (Galaxia)
I agree that in the pic in post 15 it looks to be going through the tube, but in the latest image on the far side there is a hole in the plywood not through the tube. On the other side of the hole there is something metal with a round bore in it, which I assumed was the bearing for the self-righting arm. I could be wrong, but that would mean that the hole for the self-righting arm either isn't modeled in the far tube or isn't at the same height as the one on the near side. I'll wait for some clarification from s_forbes for a final answer.
What exactly do you mean by "U shafts"? I'm not sure what you are referring to and I am having a hard time picturing how anything U shaped (or not U shaped for that matter) could connect to both arms without having to cross through the center of the robot, which I am assuming was intentionally left open to leave room for a manipulator otherwise there is no room to mount one. Also, I'm not exactly sure what problem you are trying to solve, because I only (intentionally) raised one point in that last post.
2013: Programmer
  #42   Spotlight this post!
s_forbes's Avatar
It is still mostly conceptual, so some things are missing from the model, and very few things are close to a finalized version. I think a cantilevered shaft that is attached to multiple layers of the main frame or through one of the vertical tubes would work best. But ideas change all the time as the concept progresses.
Good example: looking at the image I just posted, it occurs to me that bronze bushing would be much more suited for this mechanism than ball bearings.
  #43   Spotlight this post!
Unread 29-11-2016, 21:25
Chris is me's Avatar
AKA: Pinecone
Instead of using a solid 1/2" shaft and ball bearings for your arms, you can use a 7/8" OD .125 wall tube and bronze bushings. The bushings use the same OD bore as R8 ball bearings, and the tubing is the same weight as solid 1/2" round shaft, but the shaft is much, much, much stronger in resistance to bending, which is probably the main load to worry about here. This is one of my favorite COTS tricks for arm shafts.
  #44   Spotlight this post!
Unread 30-11-2016, 07:33
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
I took the new circle on the plywood as a bolt to help transfer torque from the plywood to the arm.
I was referring to an arm which mounted onto both uprights, not just one. It would only take up an inch on either side; the would still go across the robot either outside the frame perimeter or above the main robot chassis. This was also in response to your concern about a cantilevered shaft.
  #45   Spotlight this post!
Unread 02-12-2016, 10:09
hrench's Avatar
hrench hrench is offline
Mechanical build mentor
AKA: Bob Hrenchir
FRC #1108 (Panther Robotics)
hrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to all
Do you intend to attempt to steer (make left and right turns) when its' in strafing mode?
I anticipate you could steer with a little input from the main two wheels, but I also think this would be really difficult to implement.
