Go to Post Some advice I wish I had as a college freshman: If you don't understand it, or are struggling to keep up, ask for help. - DonRotolo [more]
Unread 30-11-2016, 10:33
whitetail's Avatar
whitetail whitetail is offline
FRC #5407 (Wolf Pack)
Team Role: Operator
whitetail is an unknown quantity at this point
Using POV in Java
I am relatively new to programming and still have a lot to learn. I found some code on an old post on Chief Delphi and I added a class and added that in but it says: public class POV implements IControl. I am wondering what it means by implementing IControl and what is IControl and how to I implement it in my code. All help is gratefully appreciated
FRC Team 5407 -Driver, Programmer and Head Control Systems Engineer
2015 MAR Championship Rookie All Star Award
2015 MAR Hatboro-Horsham District Rookie All Star Award
2015 MAR Hatboro-Horsham District event Winner(Thanks 2590, 2607)
Unread 30-11-2016, 10:42
orangelight's Avatar
orangelight orangelight is offline
AKA: Alex
FRC #0548 (Robostangs)
orangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to beholdorangelight is a splendid one to behold
Re: Using POV in Java
Can you link the CD post?
Unread 30-11-2016, 10:46
nickbrickmaster's Avatar
nickbrickmaster nickbrickmaster is offline
Not Allowed Near Power Tools
AKA: Nick Schatz
FRC #3184 (Blaze Robotics)
nickbrickmaster is an unknown quantity at this point
What exactly are you trying to do?
IControl is an interface, I assume for controllers. I've never seen it before, and unless you are implementing some custom control interface, I don't think you need it.
Just googling it, I found a Github repo from 3128 with class POV implementing IControl. IControl is a file in that same repo, and should be distributed along with POV.
I think you're putting the cart before the horse, if it were. There is probably a better way to do what you're trying to do.
I have approximate knowledge of many things.
FRC 3184: 2014-, FTC 10648: 2015-
Unread 30-11-2016, 10:49
whitetail's Avatar
Team Role: Operator
https://www.chiefdelphi.com/forums/s...&highlight=pov
Unread 30-11-2016, 11:06
AKA: Nick Schatz
Yeah, just use the getPOV() method of your joystick object. It's not hard to check this angle against constants to determine which direction is pressed.
Unread 30-11-2016, 12:57
gerthworm's Avatar
gerthworm gerthworm is offline
Making the 1's and 0's
FRC #1736 (Robot Casserole)
Rookie Year: 2015
gerthworm has a spectacular aura aboutgerthworm has a spectacular aura about
Java background - The "implements" keyword indicates that the class named POV has a required set of interface functions defined by the interface IControl. IControl effectively puts requirements on what sorts of functionality the POV class must provide. http://stackoverflow.com/questions/4...-do-on-a-class has a pretty good example.
As already mentioned, Joystick.getPOV() is probably the right answer, making the above statement relevant only for your edification.
As an example somewhat related to what you were doing, here's code our students wrote last year specific to an XBOX 360 controller, where we determine which direction(s) the POV hat is pushed based on angle criteria:
https://github.com/RobotCasserole173...ontroller.java
