Go to Post They call us super nerds. I say thank you :D - Gregor [more]
Unread 30-11-2016, 20:33
Sam Skoglund's Avatar
Sam Skoglund Sam Skoglund is offline
FRC #2232 (Deus Ex Machina)
Sam Skoglund is a jewel in the roughSam Skoglund is a jewel in the roughSam Skoglund is a jewel in the rough
WCP 32 DP Gear Pitch Diameter
I can't seem to find the pitch diameters of the 32 DP gears from WCP (pinion and 3/8" hex). Does anyone know these numbers? Or is there a way I can calculate them? Thanks in advance!
Unread 30-11-2016, 20:37
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is online now
Cothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond repute
Re: WCP 32 DP Gear Pitch Diameter
Number of teeth / Diametral pitch = pitch diameter.
Unread 30-11-2016, 20:38
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
32 DP means that a gear with 32 teeth has a 1" pitch diameter.
If you want to calculate the diameter for any 32 DP gear, then: (Pitch Diameter) = (# of teeth) / (32)
Unread 30-11-2016, 22:38
Andrew_L's Avatar
Andrew_L Andrew_L is offline
#DriveSwerveEveryDay
AKA: Drübr Inc.
FRC #1323 (Madtown Robotics) #971 (Spartan Robotics)
Andrew_L has much to be proud ofAndrew_L has much to be proud ofAndrew_L has much to be proud ofAndrew_L has much to be proud ofAndrew_L has much to be proud ofAndrew_L has much to be proud ofAndrew_L has much to be proud ofAndrew_L has much to be proud ofAndrew_L has much to be proud of
Alongside this, it's also helpful to know the equation for a gear's outer diameter: OD = (N+2)/DP, where OD is the Outer Diameter in inches, N is the number of teeth, and DP is the Diametrical Pitch of the gear (32, in this case).
Modeling the outer diameter of a gear is helpful in seeing where there's interference with other parts of the robot near the gear.
Unsure if this would be helpful, but I made this video for my students a while back, and it covers some useful gear calculations.
Unread 30-11-2016, 22:43
avanboekel's Avatar
avanboekel avanboekel is online now
AKA: Adam Van Boekel
FRC #5934 (Gear it Forward, Crowbotics)
avanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant future
What kind of adder do teams usually use for 32 DP gears? I know its usually .002"-.003" for 20 DP.
2338 Gear It Forward | Student 2010-2013 | Mentor 2014-Present | oswegofirst.org
2013 Wisconsin Regional Winner (1732, 111, 2338)
2013 Midwest Regional Dean's List Finalist
2015 Midwest Regional Chairman's Award Winner
2015 Archimedes Subdivision Winner (1023, 2338, 3996, 1089)
2016 Midwest Regional Chairman's Award Winner
4096 CTRL-Z | Mentor 2014 | team4096.org
5934 Crowbotics | Mentor 2016-Present | crowbotics.org
Unread 30-11-2016, 22:51
Two to four thou is a good place to start, but if you use the same "fudge" distance (never heard it called adder) as 20 dp gears, it won't be the end of the world. To be honest, most teams can't hold tight enough tolerances to worry about the difference.
EDIT - WCP suggests adding three thou to center distances, and it's always a good idea to listen to the manufacturer. I don't know how much clearance is added to these gears since that spec is rarely posted. I always suggest a small range so that you can adapt your adder to the application, either high torque or high speed. Course, that's assuming you can hold a thou tolerance on everything.
