Go to Post We appreciate the time/effort of everyone who contributes to Chief Delphi... hopefully, someday soon we'll be experienced/seasoned enough to contribute advice ourselves... - Michael Blake [more]
Go Back   Chief Delphi > Technical > Programming > Python
Unread 30-11-2016, 20:48
FRC Fanatic's Avatar
FRC Fanatic FRC Fanatic is offline
FRC Fanatic is on a distinguished road
Pneumatics Piston not working in python
Hello, so i'm trying to understand how to program pneumatics in python in the off-season. I've read the Robotpy documentation and the Pacgoat pneumatic documentation on github and i want to make sure that the issue is not code side, because the kFoward is functional but not the kReverse
here is a quick rundown of the pneumatic setup
double solenoid on Vex Manifold is running to 1 piston which we just want to control.
here is the code as follows
#!/usr/mybin/env python3
import math
import wpilib
from RobotMap import RobotMap
from networktables import NetworkTable
from wpilib.doublesolenoid import DoubleSolenoid
class MyRobot(wpilib.IterativeRobot):
    def robotInit(self):
        self.xb = wpilib.Joystick(2)
        self.Compressor = wpilib.Compressor(0)
        self.Compressor.setClosedLoopControl(True)
        self.enabled = self.Compressor.enabled()
        self.PSV = self.Compressor.getPressureSwitchValue()
        self.DS = wpilib.DoubleSolenoid(1,2)
        self.Compressor.start()
 def teleopPeriodic(self):
        elif(self.xb.getRawButton(2)):
                self.DS.set(DoubleSolenoid.Value.kForward)
       elif(self.xb.getRawButton(4)):
                self.DS.set(DoubleSolenoid.Value.kReverse)
is there any glaring issues? i'm new to pneumatic programming and any assistance would be great, thank you.
Unread 30-11-2016, 21:19
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
Re: Pneumatics Piston not working in python
import math
import wpilib
There are a few syntax/import issues with your code, and your teleopPeriodic function is at the wrong indentation level so it will never be called. However, the individual lines of code that set the solenoid values seem correct.
Have you tried running the code using the pyfrc simulator? That will allow you to easily test the code and see the output of any error messages. It will show solenoids turning on/off.
Unread 30-11-2016, 22:10
well about the indentation. this is actually a copy paste of the code from a word document. so the indentation would be off. but it is correct in eclipse. aright, i actually forgot about the simulator. thank you!
