Go to Post But if FIRST followed a "truth in advertising" philosophy for the registration kits, they would contain six cannisters labeled: "Stress", "Anxiety", "Confusion", "Insomnia", "Dietary Inadequacy", "Unbalanced Priorities" And a really big seventh one labeled "Fun" :) - dlavery [more]
Unread 30-11-2016, 22:51
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is offline
Registered Muser
Cothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond repute
Re: WCP 32 DP Gear Pitch Diameter
Originally Posted by avanboekel View Post
What kind of adder do teams usually use for 32 DP gears?
Two to four thou is a good place to start, but if you use the same "fudge" distance (never heard it called adder) as 20 dp gears, it won't be the end of the world. To be honest, most teams can't hold tight enough tolerances to worry about the difference.
EDIT - WCP suggests adding three thou to center distances, and it's always a good idea to listen to the manufacturer. I don't know how much clearance is added to these gears since that spec is rarely posted. I always suggest a small range so that you can adapt your adder to the application, either high torque or high speed. Course, that's assuming you can hold a thou tolerance on everything.
