Re: [FF]: 2017 Season Long Fantasy FIRST
I know there's one for IRI, and there's a standalone FIM draft this year(the rules are a little different for both), but I don't know of anyone doing a standalone Worlds draft, atleast not through this forum.
I have no plans to run a stand-alone Champs league, however. (It's going to be fun enough getting 6 divisions at each 1/2Champs drafted.) |
Erci uses the term "fun" very loosely here
Can someone explain to me why we use CD time? Everyone seems to get confused/not care about it, and, from my perspective, it's just easier to check that little box in the corner than remember that CD time is behind actual time.
#7
Because sometimes people computers are not perfectly synced. The only option would be to go by the draft runners time, which may/may not be synced properly either.
#10
It's the time that gets posted above posts, it keeps things consistent instead of people arguing about timing. You can't really argue with the time above posts. I also see no reason to have to have another tab open as a draft runner that i have to constantly check when i already have multiple tabs open dedicated to the draft that I need to check. It's really not that hard to scroll down to the bottom of the page guys.
#11
Time is good. TimeSTAMP is what gets the post.
As I said, I've sent Brandon a PM to reset the CD clock--it obviously needs it for time-dependent items. I would also note that when lists are sent in, they are considered effective whenever the slot opens--which would be when they're the next pick up (or the time turns to that slot, if someone isn't showing up). Last edited by EricH : 01-12-2016 at 19:43. |
#12
Actually I just sent Brandon a PM to see if that could be fixed. I consider 5 minutes slow to be unacceptable with the clocks at home... |
#13
We are interested in this also. Just lost a pick due to this.
