Re: [FF]: 2017 Season Long Fantasy FIRST
I have no plans to run a stand-alone Champs league, however. (It's going to be fun enough getting 6 divisions at each 1/2Champs drafted.) |
Erci uses the term "fun" very loosely here
Can someone explain to me why we use CD time? Everyone seems to get confused/not care about it, and, from my perspective, it's just easier to check that little box in the corner than remember that CD time is behind actual time.
Because sometimes people computers are not perfectly synced. The only option would be to go by the draft runners time, which may/may not be synced properly either.
#8
It's the time that gets posted above posts, it keeps things consistent instead of people arguing about timing. You can't really argue with the time above posts. I also see no reason to have to have another tab open as a draft runner that i have to constantly check when i already have multiple tabs open dedicated to the draft that I need to check. It's really not that hard to scroll down to the bottom of the page guys.
#9
Time is good. TimeSTAMP is what gets the post.
As I said, I've sent Brandon a PM to reset the CD clock--it obviously needs it for time-dependent items. I would also note that when lists are sent in, they are considered effective whenever the slot opens--which would be when they're the next pick up (or the time turns to that slot, if someone isn't showing up). Last edited by EricH : 01-12-2016 at 19:43. |
#10
Actually I just sent Brandon a PM to see if that could be fixed. I consider 5 minutes slow to be unacceptable with the clocks at home... |
#11
We are interested in this also. Just lost a pick due to this.
