Re: Where to purchase wire?
This is where we get most of our stuff as well. |
I recommend seeking out local car audio shops. Most will have a really nice high strand count silicone insulated wire that's just heaven to work with.
If not, we've recently become fans of the wire sold by Vex/WCP/CTRE/etc. This is the same wire that's used on the Talon SRX and Victor SP. Its flexibility and ease of routing totally makes up for the lack of bonded wire IMO. |
http://www.monoprice.com/product?c_i...seq=1&format=2 |
A number of years ago FRC 4607 reached out to a local distributor (for residential and commercial electricians) and the company was happy to help us out. They have supplied all of the wire, tools, terminals, etc we needed. Last year they donated more than enough wire for at least 5 more seasons (large spools of R&B for 18, 14, 12, 10, and 6ga). We are now off-loading some of this wire to the rookie teams we are mentoring.
For batteries, please contact your local Batteries+Bulbs. We have connected with two different local B+B and have received 10 batteries for the last couple of years. We just brought in 8 regulation FRC batteries from one particular B+B. |
-To start off with you measure the amount of insulation that needs to be removed, for this I hold the 45A PP contact next to the wire, keep in mind that you want wire strands in the smaller crimping part as well. I can't remember exactly, but I think that it is approximately 7mm of insulation that needs to be removed. -Using a sharp blade of a box cutter, multitool or scalpel etc, start to cut around the insulation at the 7mm mark slowly rotating the wire. You need to be careful that you only cut the insulation and not the strands of wire( they are small and easy to damage, you want every strand possible for a good connection and lower resistance). You keep cutting until you have made a slice around the entirety of the wire, making two separate bits of insulation. -You then line up the cut with the separator on the wire stripper and pull the insulation off, you could also use a pair of pliers for this. This method ensures that the insulation is the exact length that you need, it also helps you when you are crimping it as the contact sits flush against the silicon. You can do a similar cutting action with a sharp pair of side-cutters. It is actually very quick to do once you have practiced enough, Happy Crimping I'll take some photos of the various stages in the next few days. |
#7
Edit: Based on your method, are you using the good kind of wire strippers that you just squeeze instead of the kind we have? Last edited by bobbysq : 02-12-2016 at 09:29. |
