Go to Post Work hard. Then work even harder. Work until there is nothing left to work on, then work more. - RoboChair [more]
Unread 02-12-2016, 10:52
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Re: Where to purchase wire?
We get ours from EBAY and have been very happy with it.
http://www.ebay.com/itm/500-FT-12-AW...AOSw7hRWQir D
The views expressed are mine and should not be construed to represent the views of anyone else.
Unread 02-12-2016, 13:14
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Be careful about buying wire on eBay, especially marketed toward car audio. If it seems too inexpensive, it is most likely aluminum wire, which is generally a bad idea for this sort of application. In fact, it looks like the very wire you purchased is indeed aluminum wire that is copper clad, which is not the same thing as copper wire. I wouldn't use that if I were you. It used to be banned in the FIRST Robot rules. I couldn't find it in last year's rules, but I didn't look too close. Long story short, use copper wire.
Unread 02-12-2016, 13:26
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Originally Posted by sanddrag View Post
Surprised to hear that. While they do stock a lot of wire, it's often random obscure stuff, because it's surplus, and I always had trouble finding exactly what I wanted there. Maybe more recently they've gotten some new inventory.
They do have a lot of random stuff but they always have 12/2 zipwire when we go there (which admittedly is only ~3x a year).
2001-2004: Team 100
2006-Present: Team 254
Unread 02-12-2016, 13:27
rsisk's Avatar
The GURU Channel
AKA: Richard Sisk
Thanks for the heads up. Why is Aluminum wire bad?
Unread 02-12-2016, 13:33
Cory's Avatar
AKA: Cory McBride
Less conductivity for a given cross section than copper (~60% less) and significantly more likely to break when bent (much lower ductility).
2001-2004: Team 100
Unread 02-12-2016, 15:03
MrRoboSteve MrRoboSteve is offline
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
2 conductor automotive speaker wire is the way to go. Be sure you're getting stranded wire.
We order from MCM Electronics:
http://www.mcmelectronics.com/produc...6087-/24-16087
2016-17 events: 10000 Lakes Regional, Northern Lights Regional, FTC Burnsville Qualifying Tournament
2011 - present · FRC 3081 Kennedy RoboEagles mentor
2013 - present · event volunteer at 10000 Lakes Regional, Northern Lights Regional, North Star Regional, Lake Superior Regional, Minnesota State Tournament, PNW District 4 Glacier Peak, MN FTC, CMP
http://twitter.com/MrRoboSteve · www.linkedin.com/in/speterson
Unread 02-12-2016, 22:13
dardeshna's Avatar
dardeshna dardeshna is offline
Build Captain
AKA: Devin Ardeshna
FRC #0008 (Paly Robotics | Team 8)
Rookie Year: 2015
dardeshna is an unknown quantity at this point
Originally Posted by AlexanderLuke View Post
Powerwerx is typically our go-to with any zip cord. I would certainly recommend.
Thanks for all the responses!
My only hesitation about Powerwerx is it looks like we have used of their 12AWG wire in the past, and it is a bit larger in diameter than the 30AMP power pole connector crips, so we always have to cut some of the strands off. If I remember correctly, the 30AMP power poles are rated to fit on 12AWG wire, so the sizing of Powerwerx wire might be a little bit off?
Edit 1: While I'm at it, where to find 22AWG wire? Or more importantly since it is probably on one of the websites already linked, does anyone else even use it or just stick to all 18AWG?
Edit 2: It's possible we were using 10AWG and just didn't know, but curious if anyone else had this issue with powerwerx wire.
Unread 02-12-2016, 22:47
AlexanderLuke's Avatar
AlexanderLuke AlexanderLuke is offline
Do More. Less Time.
FRC #0696 (The Circuit Breakers)
AlexanderLuke is a splendid one to beholdAlexanderLuke is a splendid one to beholdAlexanderLuke is a splendid one to beholdAlexanderLuke is a splendid one to beholdAlexanderLuke is a splendid one to beholdAlexanderLuke is a splendid one to beholdAlexanderLuke is a splendid one to behold
Originally Posted by dardeshna View Post
My only hesitation about Powerwerx is it looks like we have used of their 12AWG wire in the past, and it is a bit larger in diameter than the 30AMP power pole connector crimps, so we always have to cut some of the strands off. If I remember correctly, the 30AMP power poles are rated to fit on 12AWG wire, so the sizing of Powerwerx wire might be a little bit off?
In my experience, it can be a tad difficult to fit 12AWG in the PP30 connectors, but it can work without cutting down the strands in a 12AWG wire. I like to use the PP45 more often, which is the 45amp crimp and Powerwerx even sells it as a crimp for 10AWG wire, but it's just a bit faster and easier to use when you're having difficulty making the PP30 work with you.
You can find 18AWG and 22AWG zip cord at Powerwerx.
2014-Present ~ Team 696: The Circuit Breakers - Student Leader and President, Drive Coach, Mechanical Designer
Unread 03-12-2016, 21:09
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
I just checked with Perry (pereichi), who has crimped many (possibly most) of our connections the past three years. He agrees that this is an issue, but the solution is simple - provide very little twist to the strands of the 12AWG wires, and all of the strands will fit in the 30A connector. He also agrees that once you do a severe twist, your only good solution is to bump up to the 45A connector.
Unread 04-12-2016, 00:03
AKA: Steve Peterson
Edit 1: While I'm at it, where to find 22AWG wire? Or more importantly since it is probably on one of the websites already linked, does anyone else even use it or just stick to all 18AWG?.
We use 22-2 stranded copper security system cable from Home Depot.
Unread 05-12-2016, 17:36
Travis Covington's Avatar Unsung FIRST Hero
Travis Covington Travis Covington is offline
Engineering Mentor
FRC #0254
Travis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond repute
Send a message via AIM to Travis Covington
They re-stock a lot of wire, components and tools with new inventory (not surplus).
-Travis Covington
2008-2017 - Engineering Mentor of Team 254
2001-2008 - Engineering Mentor of Team 968
1998-2001 - Mechanical Director/Driver/Member of Team 115
Unread 05-12-2016, 19:05
Labman Labman is offline
Labman
AKA: Jim Loftin
FRC #4564 (Orange Chaos)
Labman is an unknown quantity at this point
For single (not bonded) wire check out www.tinnedmarinewire.com. They have quality tinned marine wire for less money than lesser wire from other sites.
If you need 6 AWG wire for battery cable, I suggest moving up to "welding cable" with EPDM insulation. It is much more flexible than regular battery cable. Cheapest supplier is www.remybattery.com, where you can order it by the foot.
While you are at the remybattery site, check out their battery terminal covers. The "starter terminal" cover or the "straight or angled" covers beat the heck out using electrical tape.
Unread 06-12-2016, 02:06
dardeshna's Avatar
Build Captain
AKA: Devin Ardeshna
Rookie Year: 2015
Welding cable has worked really well for us this past off season, so +1 agreed. As far as the 12awg wire, looks like we'll be purchasing from powerwerx and trying out 45amp connectors.
Unread 06-12-2016, 06:26
pribusin's Avatar
pribusin pribusin is offline
Uber Alien
AKA: Mike 1
FRC #4004 (M.A.R.S. Rovers)
pribusin has a spectacular aura aboutpribusin has a spectacular aura aboutpribusin has a spectacular aura about
Be careful when buying speaker wire as it is often labelled as GA and not AWG. The two are NOT equal . If you look in the description of that eBay listing it even says so. Less experienced teams may mistake 16GA equal to 16AWG - it is NOT the same. Make sure your wire is labelled __AWG.
Unread 06-12-2016, 23:46
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
Just got embroiled in a shop project, I need #8/4 copper to set a sub-panel. Recommendations in northern DE? Need 70', sheathed so I can run it along and then through a wall. Would like stranded to make some corners go easier.
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
