Go to Post What's so bad about Matt? I mean, if the guy can explain PID so that even I can understand it, he can't be all that bad... - Billfred [more]
Go Back   Chief Delphi > Other > Chit-Chat > Games/Trivia > Fantasy FIRST
  #151   Spotlight this post!
Unread 01-12-2016, 19:32
EricH EricH is online now
Re: [FF]: 2017 Season Long Fantasy FIRST
Originally Posted by TDav540 View Post
Can someone explain to me why we use CD time? Everyone seems to get confused/not care about it, and, from my perspective, it's just easier to check that little box in the corner than remember that CD time is behind actual time.
Standard time reference.
Actually I just sent Brandon a PM to see if that could be fixed. I consider 5 minutes slow to be unacceptable with the clocks at home...
  #152   Spotlight this post!
Unread 01-12-2016, 19:33
Harrison.Smith Harrison.Smith is online now
Business, CAD, Mechanical
Harrison.Smith is a name known to allHarrison.Smith is a name known to allHarrison.Smith is a name known to allHarrison.Smith is a name known to allHarrison.Smith is a name known to allHarrison.Smith is a name known to all
We are interested in this also. Just lost a pick due to this.
“Rest and be thankful.” — William Wadsworth
Team 1296: 2014 - 2016
  #153   Spotlight this post!
TDav540's Avatar
TDav540 TDav540 is offline
Questionable Decisionmakers
AKA: Trevor Davidson
FRC #1648 (G3 Robotics)
TDav540 has much to be proud ofTDav540 has much to be proud ofTDav540 has much to be proud ofTDav540 has much to be proud ofTDav540 has much to be proud ofTDav540 has much to be proud ofTDav540 has much to be proud ofTDav540 has much to be proud of
Why couldn't everyone just check that with this then?
2015-??: FRC 1648, G3 Robotics
2016 Carver Division, Columbus District Chairman's Award, Albany District Finalists
Georgia Tech, Class of 2019; Emcee, Ref, and 2016 Technology Enrichment Presenter
2011-15: FRC 540, TALON 540 Godwin Robotics
Proud Alumnus and Supporter
2015 Newton Division, Virginia Regional Finalist Alliance Captain
2014 Curie Division, Virginia Regional Engineering Inspiration
2013 Curie Division, Virginia Regional Engineering Inspiration
  #154   Spotlight this post!
Unread 01-12-2016, 19:36
TRF would be in support of this.
  #155   Spotlight this post!
Unread 01-12-2016, 19:37
JosephC's Avatar
JosephC JosephC is offline
FF: Breakfast Company
AKA: Joseph Cupchack
no team (FiM Volunteer Extraordinaire)
JosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond repute
It's the time that gets posted above posts, it keeps things consistent instead of people arguing about timing. You can't really argue with the time above posts. I also see no reason to have to have another tab open as a draft runner that i have to constantly check when i already have multiple tabs open dedicated to the draft that I need to check. It's really not that hard to scroll down to the bottom of the page guys.
Referee: 2015 - ?
Field Reset/Supervisor: 2013 - ?
68 Team Member: 2011 - 2013
  #156   Spotlight this post!
Unread 01-12-2016, 19:39
Time is good. TimeSTAMP is what gets the post.
As I said, I've sent Brandon a PM to reset the CD clock--it obviously needs it for time-dependent items.
I would also note that when lists are sent in, they are considered effective whenever the slot opens--which would be when they're the next pick up (or the time turns to that slot, if someone isn't showing up).
  #157   Spotlight this post!
Unread 01-12-2016, 19:41
frcguy's Avatar
frcguy frcguy is offline
Unregistered Unuser
AKA: Nicholas Dal Porto
FRC #5940 (B.R.E.A.D.)
Team Role: Tactician
frcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond repute
Originally Posted by Cothron Theiss View Post
Ok, thanks! If someone else sees this and becomes consumed with the idea of creating a stand-alone Champs league, I'll probably try and participate. But I'd say it's a bad idea to try and start a league myself without ever having played. Maybe next year.
I'm also interested in a stand alone draft but I'm in the same boat as Cothron in terms of not wanting to run it because of inexperience.
2016: Team 5940 (Silicon Valley Regional Rookie All-Star and Quarterfinalist, Curie Quarterfinalist)
Volunteer: 2016 (Chezy Champs Field Reset, Capital City Classic FTA, MadTown ThrowDown FTA)
  #158   Spotlight this post!
Unread 01-12-2016, 19:45
JosephC's Avatar
I'd recommend making a separate post to gauge interest and gather members, the SLFF main thread isn't the place to setup a non-SLFF draft.
Referee: 2015 - ?
  #159   Spotlight this post!
Unread 01-12-2016, 20:46
JosephC's Avatar
In lieu of a skew of issues with live drafting so far, I've decided to make a small "How to live draft" guide.
#1 - Keep an eye on ChiefDelphi time, it's approximately 5 minutes and 20 seconds behind the actual time. It is located at the bottom of the page, and this is the time we use for every draft.
#2 - Refresh the page before you post.
#3 - You're available to pick when the following conditions are met.
Your pick slot is up based on chiefdelphi time, or the person with the time slot before yours has picked.
#4 - Make sure the team you are picking is attending the event, and has not already been picked.
Or you can just send in a list, it's easier for everyone trust me.
Referee: 2015 - ?
  #160   Spotlight this post!
Unread 01-12-2016, 22:27
TDav540's Avatar
I'd like to propose that randomization for the next series happen at the conclusion of tomorrow's drafts (Miami Valley and Central Valley). That gives teams plenty of time to analyze which picks they own for the next set and prepare trade offers if they so choose.
Also, everyone should read Joseph's post, because it's spot on.
  #161   Spotlight this post!
Unread 02-12-2016, 00:09
tindleroot tindleroot is offline
Free Scouting Help to All
AKA: Casey LeeVan
FRC #4272 (Maverick Boiler Robotics)
tindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond reputetindleroot has a reputation beyond repute
One extra thing to expand on #4 is to make sure that you are typing the correct team number that you want to pick. I know this has been an issue with 2502 and 2052 at their respective Minnesota regionals, for example, but it's always easy to let a typo slip through. There are over 6000 team numbers - make sure you're typing the right one.
2012-2013: FTC 4601 (student)
2014-2015: FRC 135 (student) - 5 banners in 2 years!
2016-present: FRC 4272 (mentor)
Thanks to all of our alliance partners!
11, 51, 68, 201, 234, 868, 1108, 1241, 1760, 3147, 3301, 3487, 3865, 4269, 4485, 4580, 5188
  #162   Spotlight this post!
Unread 02-12-2016, 11:35
TDav540's Avatar
Falcon and Questionable Decisionmakers have completed a trade and it is currently available for review:
Falcon Receives:
#9 Ventura
#10 Ventura
#3 Central Valley
Questionable Decisionmakers Receive:
#1 Ventura
#18 Ventura
#4 Central Valley
  #163   Spotlight this post!
Unread 02-12-2016, 14:23
MARS_James's Avatar
MARS_James MARS_James is offline
Always Scouting
AKA: James Comstock
FRC #0179 (The Children of The Swamp)
MARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond repute
Send a message via AIM to MARS_James
So I have been thinking about something that has been bugging me for a while about the COI drafts. I think that if you are in need of a COI draft it is unfair if you are first pick, both to you and the league as a whole as whoever is second pick effectively gets to be first pick twice in a row. So I propose if a COI draft is called that event becomes a specific draft order for that round, basically we skip the normal rotation for that draft and switch it with the draft where the person in need of COI is at a specific location in the draft. I believe this position should be the middle spot (rounded down) so since we have 9 this year it would be position 5, if we have 8 it would also be position 5 since it is rounded down.
The reason for this specific position as I feel that the middle spot has the least impact on the draft, since putting them last basically gives the person who is second to last a 2 pick swing.
Driving Record: 24-8
Coaching Record: 66-31
2014 South Florida Regional Woodie Flowers Finalist
  #164   Spotlight this post!
Unread 02-12-2016, 14:26
TDav540's Avatar
So what you're proposing is that this draft be moved in the rotation so that the person calling the COI is sitting position 5? That sounds reasonable to me.
  #165   Spotlight this post!
Unread 02-12-2016, 14:51
jlmcmchl jlmcmchl is offline
FF - The Breakfast Company
AKA: Jordan McMichael
FRC #0027 (Team RUSH 27)
jlmcmchl has much to be proud ofjlmcmchl has much to be proud ofjlmcmchl has much to be proud ofjlmcmchl has much to be proud ofjlmcmchl has much to be proud ofjlmcmchl has much to be proud ofjlmcmchl has much to be proud ofjlmcmchl has much to be proud of
A problem still arises in this situation if two teams have approved COIs for a draft. If we have the first and last picks, which are the strongest positions to draft from (At least, for deeper events) declare and approve COI, what rotation do we choose? Say, for two teams that declare COI, they're at positions 1 and 6 in that draft. If we choose the rotation that moves 1 to the 5th draft spot, then the 6th place w/ an approved COI would be in the 1st position for the draft, leaving us with the same conundrum.
Instead, I propose this as a solution:
Remove all teams which have submitted a COI from the draft list, and mention them elsewhere as having a COI draft for that event. This should probably be in the SLFF Draft Spreadsheet.
For the remaining participating teams, randomize the draft order independent of the current rotation, and proceed to draft normally with the participating teams.
For the COI teams, leave their picks as COI until the corresponding FRC event has completed and assign them teams at random off the top of the random list. (I believe this is the same as COI Draft Implementation in the new rules)
While this does undermine our goal of rotating everyone through 1st pick, it's just one draft very infrequently and doesn't mean much in the full scale of SLFF. With as many drafts as we run, it won't cause us to deviate significantly from this intention.
Field reset: Kettering Kickoff ('13, '14), Kettering ('14, '15), Bedford ('14), Woodhaven ('16), Carver ('16), Einstein! ('16)
Referee: Bedford ('15), MARC ('15, '16), Kettering Kickoff ('15, '16), Kettering District (#1&2: '16), Troy ('16)
Last edited by jlmcmchl : 02-12-2016 at 14:56. Reason: Clarification on draft position issue
