Go to Post Courtesy and kindness should be the words for the weekend. - IndySam [more]
Go Back   Chief Delphi > Other > Chit-Chat > Games/Trivia > Fantasy FIRST
  #166   Spotlight this post!
Unread 02-12-2016, 16:17
MARS_James's Avatar
MARS_James MARS_James is online now
Always Scouting
AKA: James Comstock
FRC #0179 (The Children of The Swamp)
Team Role: Tactician
MARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond repute
Send a message via AIM to MARS_James
Re: [FF]: 2017 Season Long Fantasy FIRST
Originally Posted by jlmcmchl View Post
A problem still arises in this situation if two teams have approved COIs for a draft. If we have the first and last picks, which are the strongest positions to draft from (At least, for deeper events) declare and approve COI, what rotation do we choose? Say, for two teams that declare COI, they're at positions 1 and 6 in that draft. If we choose the rotation that moves 1 to the 5th draft spot, then the 6th place w/ an approved COI would be in the 1st position for the draft, leaving us with the same conundrum.
Instead, I propose this as a solution:
While this does undermine our goal of rotating everyone through 1st pick, it's just one draft very infrequently and doesn't mean much in the full scale of SLFF. With as many drafts as we run, it won't cause us to deviate significantly from this intention.
This solution could prevent someone from achieving a first pick in that round which would be a big impact potentially, although i see your point with 2 teams potentially needing COI in which case i feel we combine our two ideas so:
If one team needs a COI we make the draft in which the COI is needed to be the draft that they are in the median pick position, rounded down
If >1 teams need it for a particular draft the draft is rescheduled to be the first in the rotation, the runner for that position randomizes all teams except those in need of COI. After randomizing those teams are put in median position rounded down (With 9 of us that means 5 and 6 with 8 it means 4 and 5) If three or more need it it still proceeds the same (9 people it is 4 5 and 6 with 8 it is also 4 5 and 6)
Driving Record: 24-8
Coaching Record: 66-31
2014 South Florida Regional Woodie Flowers Finalist
  #167   Spotlight this post!
Unread 02-12-2016, 18:49
JosephC's Avatar
JosephC JosephC is offline
FF: Breakfast Company
AKA: Joseph Cupchack
no team (FiM Volunteer Extraordinaire)
JosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond repute
Technical Difficulties are preventing me from posting tonights draft, more specifically, I can't get the teams list for CVR. https://puu.sh/sCekO/d2be13dfe9.png
(If someone could post it within the next 5 minutes thatd be great)
Referee: 2015 - ?
Field Reset/Supervisor: 2013 - ?
68 Team Member: 2011 - 2013
  #168   Spotlight this post!
Unread 02-12-2016, 18:53
TDav540's Avatar
TDav540 TDav540 is online now
Questionable Decisionmakers
AKA: Trevor Davidson
FRC #1648 (G3 Robotics)
TDav540 has much to be proud ofTDav540 has much to be proud ofTDav540 has much to be proud ofTDav540 has much to be proud ofTDav540 has much to be proud ofTDav540 has much to be proud ofTDav540 has much to be proud ofTDav540 has much to be proud ofTDav540 has much to be proud of
294
670
687
751
852
972
973
980
1072
1323
1388
1422
1671
1678
1868
2085
2135
2367
2437
2493
2643
2761
3045
3256
3303
3495
3501
3970
4255
4276
4415
4543
4645
5104
5134
5677
5817
5852
6305
6650
6657
6699
2015-??: FRC 1648, G3 Robotics
2016 Carver Division, Columbus District Chairman's Award, Albany District Finalists
Georgia Tech, Class of 2019; Emcee, Ref, and 2016 Technology Enrichment Presenter
2011-15: FRC 540, TALON 540 Godwin Robotics
Proud Alumnus and Supporter
2015 Newton Division, Virginia Regional Finalist Alliance Captain
2014 Curie Division, Virginia Regional Engineering Inspiration
2013 Curie Division, Virginia Regional Engineering Inspiration
  #169   Spotlight this post!
Unread 02-12-2016, 19:05
JosephC's Avatar
Thanks
Referee: 2015 - ?
  #170   Spotlight this post!
Unread 02-12-2016, 19:22
Short note: Anybody thinking the CD clock is still late, it's now caught up to the rest of the world.
  #171   Spotlight this post!
Unread 02-12-2016, 20:31
I highly doubt that there will be two COI requests in the same draft. That being said, I have no problems at all with putting COI drafts in the middle (slots 4, 5, or 6) by swapping with another draft. Note that this means that COI requests will need to be in early, so that they can be announced.
Modified proposal: Standard COI procedure is to use the next draft order that places the requester(s) in the middle of the order, and replace that draft with the COI draft's normal order. (If a COI is known in advance, and a previous draft order works better, that may also be used if that draft has not run yet.) Should that not be possible due to multiple requests, a special draft will be added into the normal rotation as follows: Randomize all non-COI players, then insert all COI players into the middle slots in random order. Rotation resumes after said draft.
Middle of the draft order is determined by number of players in the league.
Speaking of which: Falcon is requesting a COI in Orange County. I sent the reason to Joseph and James last week. (Just our luck, it's a randomization draft.)
  #172   Spotlight this post!
Unread 02-12-2016, 20:35
BTW: Random draft order for Greater Kansas City is:
Untitled Team
F3
The Breakfast Company
FIRST Pick
NE Way You Want It
Swamp Life
Falcon
The Regal Falcons
  #173   Spotlight this post!
Unread 03-12-2016, 18:59
Brian Maher's Avatar
Brian Maher Brian Maher is online now
FRC #2791 (Shaker Robotics), FRC #1257 (Parallel Universe)
Brian Maher has a reputation beyond reputeBrian Maher has a reputation beyond reputeBrian Maher has a reputation beyond reputeBrian Maher has a reputation beyond reputeBrian Maher has a reputation beyond reputeBrian Maher has a reputation beyond reputeBrian Maher has a reputation beyond reputeBrian Maher has a reputation beyond reputeBrian Maher has a reputation beyond reputeBrian Maher has a reputation beyond reputeBrian Maher has a reputation beyond repute
Hey, when is the Utah thread being posted?
2016-present, Mentor, FRC 2791 - Shaker Robotics
2016: Tech Valley SF (5236, 2791, 3624) and Quality, Finger Lakes SF (5254, 2791, 2383), Battlecry@WPI Winner (195, 2791, 501), Robot Rumble Winner (2791, 195, 6463)
2016-present, Mentor, FRC 1257 - Parallel Universe
2016: Mount Olive Winner (1257, 5624, 1676), Bridgewater-Raritan Finalist (1257, 25, 3340, 555) and GP, MAR CMP Winner (225, 341, 1257), Archimedes SF (4003, 4564, 5842, 1257), IRI Invite
2012-2015, Student, FRC 1257 - Parallel Universe
2015: Mount Olive QF (1257, 1811, 1923) and Safety Award, North Brunswick Finalist (11, 193, 1257) and Team Spirit and Safety Awards
2014: Clifton Winner (1626, 869, 1257), MAR CMP QF (1257, 293, 303)
2013: TCNJ Safety Award
2012: Mount Olive QF (204, 303, 1257)
  #174   Spotlight this post!
Unread 03-12-2016, 19:01
BrennanB's Avatar
BrennanB BrennanB is offline
TBC is good at getting almost first
AKA: Brennan Bibic
FRC #4476 (W.A.F.F.L.E.S.)
BrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond repute
Whenever Joe doesn't afk :'(
Brennan Bibic - @b_bibic - Eh-Nalysis
10 years of inspiration compilation - W.A.F.F.L.E.S. #4476 YouTube Channel - 64 events and counting!
FRC 2013-2017 (W.A.F.F.L.E.S. Community Robotics #4476) - FLL 2006-2017 (W.A.F.F.L.E.S. #105) - VRC 2010-2013, 2015-2016 (W.A.F.F.L.E.S. #4476)
FRC 2009-2012 (K-Botics #2809)
Fantasy First 2014-2017 (The Breakfast Company) #TBCWin
2014 Dean's List Finalist
"Work until your idols become your rivals."
  #175   Spotlight this post!
Unread 03-12-2016, 19:05
Might have to postpone to Tuesday--hate to take part of a break day away, though.
  #176   Spotlight this post!
BrennanB's Avatar
AKA: Brennan Bibic
I got it covered up in a sec
  #177   Spotlight this post!
Unread 03-12-2016, 19:24
JosephC's Avatar
The yung power outage strikes again, I swear it happens to me atleast 1 draft a year. (My phone wasn't charged when I woke up, so I had no way to contact anyone until it conveniently came up 20m late -.-)
Brennan has all the lists for UT.
Referee: 2015 - ?
  #178   Spotlight this post!
Unread 03-12-2016, 23:15
Golfer4646's Avatar
Golfer4646 Golfer4646 is offline
[SLFF]: The Breakfast Company
AKA: Nicholas L.
FRC #4646 (Team ASAP)
Team Role: Student
Golfer4646 is a splendid one to beholdGolfer4646 is a splendid one to beholdGolfer4646 is a splendid one to beholdGolfer4646 is a splendid one to beholdGolfer4646 is a splendid one to beholdGolfer4646 is a splendid one to beholdGolfer4646 is a splendid one to behold
Untitled Team and The Breakfast Company have agreed to a trade involving the Greater Kansas City and Central Illinois Regionals.
The trade agreement is:
Untitled Team receives:
#15 overall at the Central Illinois Regional
#4 overall at the Greater Kansas City Regional
#15 overall at the Greater Kansas City Regional
The Breakfast Company receives:
#16 overall at the Central Illinois Regional
#2 overall at the Greater Kansas City Regional
#17 overall at the Greater Kansas City Regional
I tried to enter this into the pending trades sheet, but may not have done so correctly.
  #179   Spotlight this post!
Unread 04-12-2016, 00:05
The entry was correct. However, it does help to look at the approved trades sheet. Untitled's #16 was already traded to TBC for the #11. Can't trade the same pick twice.
  #180   Spotlight this post!
Unread 04-12-2016, 00:33
BrennanB's Avatar
AKA: Brennan Bibic
That shouldn't have gone through since Untitled double booked us and instead the deal went to QD
