Go to Post Making GP a rule would be the equivalent of making a law that says you have to help get kittens out of trees. - Molten [more]
Unread 23-01-2002, 17:26
Randy_Ai Randy_Ai is offline
Randy_Ai is an unknown quantity at this point
Cool Question about wheels
Where are we allowed to buy wheels? (Anywhere?)
Are there any restrictions on type/nature of the wheels?
Furthermore, are there any restrictions on the size or shape of the wheels?
Randy and Ken,
team #820
Unread 23-01-2002, 17:33
Kai Zhao Kai Zhao is offline
#0686 (Bovine Intervention)
Kai Zhao is on a distinguished road
Send a message via AIM to Kai Zhao
The only place I know that we can buy wheels is Skyway.
Visit http://www.skywaytuffwheels.com
Their wheels are pretty cheap. Most of them are under $20. Any wheel from Skyway is allowed. But of course you can make your own wheels
Unread 23-01-2002, 17:38
we don't plan on "making our own wheels"
Basically, we're trying to figure out if we are allowed to purchase wheels from an alternate supplier.
Unread 23-01-2002, 18:07
Jordan A.'s Avatar
Jordan A. Jordan A. is offline
#0781 (Kinetic Knights)
Jordan A. is an unknown quantity at this point
Send a message via ICQ to Jordan A.
Randy, I beleive us canadian teams were granted a little breathing room, if you find a supplier of exact duplicates of restricted parts you can buy there. Namely SPI stuff.
Talk to you main contact (probably you teacher) Mark Breadner sent out a e-mail a while ago about a canadian skyway wheel distributor.
Unread 24-01-2002, 13:11
AdamT's Avatar
AdamT AdamT is offline
#0401
AdamT is on a distinguished road
Word of caution...
Buying wheels, if they make high traction wheels great, but those wheel chair wheels are useless. That is, unless you cut them up. If you don't have the time to build wheels, ya know do what you can. If you have a little extra time, look into building wheels. Two plywood circles spaced apart with cut up wheel chair wheels will do a great job. Shoot, our tread last year was made out of cut up wheel chair wheels, chain, spacers, and aluminum channel.
~Adam
Unread 24-01-2002, 13:36
jonnywalk jonnywalk is offline
jonnywalk is an unknown quantity at this point
Send a message via AIM to jonnywalk
Wheels
I suggest tracks myself, that is what we are using. If you use chain on the tracks watch binding it up when you turn. Ask Adam about their robot last year. They had a great design and yes it was totally Lexan but I think they had a problem turning. But if you choose to use wheels I would suggest going with the ones for motorized wheelchairs as they have tread on them if not you can always cut tread or attach some form of cleat onto the wheel.
Unread 24-01-2002, 14:56
Wayne Doenges's Avatar
Wayne Doenges Wayne Doenges is offline
We Build Robots......and Careers
AKA: Warthog
FRC #1501 (Team T.H.R.U.S.T.)
Wayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond repute
Last year our team used the wheelchair wheels. We used a sloldering iron with a "V" shaped tip to cut tread into the tires. We had excellent grip. We could tow a fully loaded stretcher over the bridge without any loss of traction.
We cut the treads in at about .25" apart and .125" deep.
Hope this helps.
Wayne Doenges
We Build Robots and Careers
World's - #1 seeded in Archimedes, WON Archimedes and made it to Einstein
2016 NC District - Guilford County. #13 seeded, Finalist. Won Quality award.
IN District - Tippecanoe. #4 seeded. Won Innovation in Control award.
IN District - Perry Meridian. #3 seeded. Finalist. Won Excellence in Engineering award.
IN District - State Championship. #1 seeded. Finalist. Won Excellence inn Engineering award.
Unread 24-01-2002, 15:08
Wheels vs track
I was just suggesting tracks as an opinion. However, with 130lbs of machine if you position the weight over the drive wheels you are going to get pretty good tracking on carpet so I don't think teams are going to have to worry about that too much unless you really mess up with the weight. Plus the feild is level
Unread 24-01-2002, 15:34
Keithicus Keithicus is offline
#0920 (Lancers)
Keithicus is an unknown quantity at this point
jonny,
Lets remember, the team that designs for "pretty good" traction will be beat by the team with pretty better traction.
We're doing lexan wheels with aluminum cleats. Gotta make sure they dont tear up carpet, though. Also heard that the pnuematic wheels from skyway work good.
Unread 24-01-2002, 17:14
AdamT's Avatar
#0401
We're building "drums" and wheels, both secret materials....right.
~Adam
What do you use for wheels? Andrew Technical Discussion 36 08-01-2004 10:20
Q&A Traction Question answer Cory Technical Discussion 4 09-01-2003 06:37
Lots of Wheels and F = u x N archiver 2001 17 23-06-2002 23:37
Good or bad: back wheels coming off the ground Gui Cavalcanti Technical Discussion 2 17-03-2002 22:09
