Go to Post Waiting for the kick off is like studing the molecular structure of grass while being hit on the head by a frying pan - infinitydex [more]
Unread 03-12-2016, 10:36
Ari423's Avatar
Ari423 Ari423 is offline
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant future
Re: pic: ???
Originally Posted by PAR_WIG1350 View Post
It's an octagonal frame and belly pan, standing on its side. Given the lack of wheel cutouts along the edge closest to the table, and various holes placed elsewhere, it is uses four omni wheel, one at each corner short edge. The rivet mandrel stabbed into the table is just a distraction.
Originally Posted by Cothron Theiss View Post
Swerve is also a possibility. The swerve modules might attach at the mounting holes in the bellypan. My question is, why does all your tubing and gussets look like it's been faced off on a mill or lathe?
That's a very pretty bellypan, by the way.
If you look at the far corner, there is what appears to be a bearing hole in the 45* piece. I would assume that is where an omni wheel would go for 4-wheel kiwi.
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
