Go to Post Prove me wrong. :) - Kris Verdeyen [more]
Unread 03-12-2016, 23:26
headlight headlight is offline
headlight is an unknown quantity at this point
Re: Exhaust in Solenoids
A single solenoid should be enough to control both the A and B ports. The important thing is that it is a 4/5 port solenoid.
If there is air leaking out of the exhaust port it is usually either an internal leak in the seal of the air cylinder or a leak in the gasket between the solenoid and the manifold block (if you are using a manifold setup).
